Question about Brother MFC 210C All-In-One InkJet Printer
My mfc-210c says unable to clean how do we fix this?
  • 4,041 Answers
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All the best Pineworks
Posted on Apr 28, 2010
  • irlabrat Dec 31, 2010
    I used the second fix and it worked perfectly. Very appreciative . You are so smart! Rebecca
  • hchap Mar 27, 2011
    I used the second fix and all is great thank you so much.
Brother 210C printer unable to clean
you need to replace ink pads and reset the ink pad count
Nov 19, 2012 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean printer
can clean the printer always say unable cleaning
Brother MFC 210C printer unable to clean print head. How can I clean it manually? The inkjet cartridges are full but the printer does not print. Error message on display: unable to clean.
If your printer is like the 420CN Model, do not forget to disconnect the printer for resetting purposes and connect it again and it may clean properly and run fine. Good luck! hopes it work. It did for me. My printer is working fine and I like it. It does the work.
Aug 02, 2010 | Brother MFC 210C All-In-One InkJet Printer
My mfc 210c is unable to clean and therefore I
Unable to clean means the waste ink is full, about 1 hour labor and $20.00 part. With the new machines running about $100.00 it's probably not worth the repair.
Oct 26, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean?
Heres the mauel for the MFC-210C printer.
http://www.brother-usa.com/manuals/default.aspx?PRODUCTID=MFC210C&ProductGroupID=5
You can clean the outside of the printer and the paper handling mechanisms with a mild cleaning solution and a lint free cloth. To clean the insdie of the printer, use a HEPA vacuem and follow the manuels recommendations.
Nov 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
My Brother MFC-C
I have the same problem as amira58 - the machine keeps telling me it's unable to clean, therefore I am unable to use my printer which is mfc-215c.
Can you advise how I fix this problem ??, especially with the price of a new colour printer now below $100 - is it worth my taking it to a techno to get it fixed (printer is about 4 years old). Look forward to your response. Ahi Allen
Aug 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Mfc 215c unable to clean
Problem was fixed. See link below by SkipperOz
http://www.fixya.com/support/t485892-error_46_unable_init
Solution applies to MFC-5440CN but also applies to MFC-215C.
Jun 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C problem
press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
Jan 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
hi this a fateful malfunction only a technician can fix this good luck
Apr 06, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
673 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
