Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My kenmore refrigerator will not make ice. I had to unplug it for about 8 hours and when I hooked it back up, it won't make ice. I changed the filter and still no ice. It does not look like it getting water
  • kendowning Apr 28, 2010
    How should I take off the water valve to the refrigerator. I don't want to break the hose. Do I pry it off. There is no screw. It looks like it should just pop off but I really do not know. The hose leads right into the refrigerator.
  • Rick Ead
    Rick Ead May 11, 2010
    did you check the valve in the back of the unit. the water connection goes to that valve if you follow the hose that goes to your ice maker then disconect the hose going to the valve to assure that you are getting water
  • 1,998 Answers
Does it have a quick connect on the valve if so push the outter rim in while slowly pulling the hose out
Posted on Apr 29, 2010
Had ice forming in the back of my Kenmore refrigerator 106.6215211.I
Unplug and put a pot of boiling water in side and shut the door check in a few hours you will be good to go
May 24, 2016 | Kenmore Refrigerators
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore side by side icemaker quit working after a power outage. Is there a reset button? The tray has ice but it won't cut or dispense the ice
If you are having a problem with your Kenmore refrigerator's automatic defrost feature, it can lead to issues with the appliance's performance. The Kenmore self-defrost system works similarly to that of other refrigerator brands and it has similar components that can potentially malfunction and cause the entire system to fail. While you can still manually defrost your Kenmore by opening the doors and unplugging the unit for several hours, it is inconvenient and messy to clean up. Your best bet it to find the issue and repair it.
Jul 27, 2012 | Refrigerators
I disconnected icemaker to put in new floor, i hooked it back up, now my icemaker wont make ice. its going thru the motions but water isnt coming in.
does this unit have a water filter on it. may want to check filter if so alot of times when you turn water off there will be some sediment /trash come through system and could get lodges in line,filter assembly.. change filter out... you may also have some debri at water valve remove water line from vale and then check connection for any sediment prior to reconnecing turn water on to line holding a glass to catch the water. reconnect adn wait 6- 8 hours to see if ice maker fills with water...you can jump ice maker out by removing front cover and advancing timer.
Jan 02, 2011 | Kenmore Side by Side Refrigerator
My Kenmore side by side, the freezer will operate for about 3 days before it ices up and food defrosts. I will unplug it for about 7-8 hours and start it back up and it works for 3 days. What is really...
either the defrost heater in the freezer compartment underneath the evaporator coil is open and cannot heat or the defrost timer/adaptive defrost control in the refrige compartment is defective
Jun 18, 2010 | Kenmore 57029 Side by Side Refrigerator
Replace icmaker on kenmore
Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker won"t work
Give it at least 24 hours to get started. May need to turn freezer colder also.Make sure Arm on ice maker is not locked in up position. I don't know what jump means. If it has been in frig for a long period with out water but still going through the motions there could be other problems. But if it was just hooked up give it time to get going.
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Kenmore Elite Trio
pull the kickplate or look on the back of the unit in the compressor comparment some where on that unit is a tech sheet that will explain that code i dont have access to kenmore tech data as sears tends to keep a pretty good lid on it but if you find the sheet and reply i can help
Jan 19, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
476 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
