Question about Alpine CDA-9825 CD Player
Have a alpine cda-9825 head unit that turns my amp off only when it on the tuner and not the cd whats going on
  • jadedogy Apr 28, 2010
    i tried turning the volume all the way down and changeing sources it didnt make a differnce. i have the remote turn on for the amp wired to the blue wire with the white strip. it seems only that source makes it turn off is not in safe mode all the lights turn off on tuner and it all comes back on with any other source
  • 496 Answers
Turn your volume down before you switch what maybe happening is that you amp is over heating and going into "safe mode" and turning itself off. I have seen that happen before because the radio signal is " loader " then the cd. If it's still not giving you any love you may have a short somewhere. what wire do you have the remote to your amp hooked to?
Let me know what happens, Good luck
Mark
C.C. Motorsports
Posted on Apr 28, 2010
Alpine CDA-9885 has no sound to rear speakers when playing a CD. Works OK when in tuner mode?? What up??
Are you running your rear speaker through an amplifier? If so, you are probably using the blue wire (power antenna remote turn on) instead of the blue/white wire (amp remote turn on). The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Jul 10, 2012 | Alpine CDA-9855 CD Player
Alpine CDA-9831 No Sound From CD's? My Alpine 9831 has always worked fine on the "Tuner" setting in my stock 3 series BMW. But recently I put a CD in for the 1st time and the head unit shows...
Are you using an amplifier? If so make sure you are using the blue/white wire to turn your amp on. The blue wire is power antenna turn on and turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
I have a CDA-9855 Alpine head unit. It worked just fine when removed from my prior vehicle (05 VW Golf). I just installed it in an 01 Land Rover Discovery II using a wiring harness adapter so no cutting or...
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
Jan 26, 2011 | Alpine CDA-9855 CD Player
When head unit is on tuner everything is fine when on ipod or cd mode there is no sound ...i have taken off the face and reset the unit and still tuner sound on ipod and cd sound off
are you using an amplifer? if so, it sounds like you are using the blue wire instead of the blue/white wire to turn the amp on. the blue is antenna remote and turns of when it is not in tuner mode. the blue/white is amplifier remote.
Oct 28, 2010 | Alpine CDA-9883 CD Player
Amp shuts off when trying to play cd
it sounds like you have the amp hooked up to the power antenna lead instead of the amp remote lead. should be two blue wires.
Jul 29, 2009 | Car Audio & Video
Volume problem with the AUX input using iPod
Do you have the ipod turned up too? Whats happening is the alpine is getting to low of a foltage signal.
Jul 30, 2008 | Alpine CDA-9825 CD Player
Alpine cda-9811 is not accepting amp as external amplifier?
The signal should go from the head unit to the amp to the subs. Someone must not have wired the subs correctly through the amp, or amp to the cd player..
Jul 08, 2008 | Alpine CDA-9811 CD Player
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
Jun 19, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
Alpine CDA-9825 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
