Question about Kenmore 96012 / 96014 / 96019 Electric Kitchen Range
The baking element isn't working.
The baking element got really bright in one spot while the oven was on 350F and then it no longer worked. It looks like the coating or whatever on the oven baking element is missing now and the oven won't heat up at all. Can I replace just this part or will I have to get a new oven?
    Guru:
  • 60 Answers
You can replace the element. The element should just plug in to the oven. You might have to remove a few bolts that hold the element in place. Get the model number of your range and call your local appliance stores, or order it online. Unplug the old element and plug in the new element.
Posted on Apr 28, 2010
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Why does it take more than 30 minutes to preheat my oven to 400 degrees?
DO YOU HAVE A GAS OR ELECTRIC OVEN???
Gas oven----the bake ignitor is weak and needs repalcing
Electric oven---- does the element glow bright red,if yes swap out for new one---if no need to call for
service and see why voltage to bake element isn't correct
Jul 30, 2011 | GE Ovens
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 | Ovens
Kenmore 96012 / 96014 / 96019 Electric Kitchen Range Logo
231 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
