Question about Freezers
Why defrost switch not return to normal position
  • Rick Ead
    Rick Ead May 11, 2010
    is ther an ice blockage in back of the panel? have u checked to see if you have a mechanical or electronic defrost timer?
    Guru:
  • 1,524 Answers
Bad timer.
Posted on May 01, 2010
Coldspot model: 106 725540 freezes sometimes
You can by pass it but I wouldn't. You may need to replace the t'stat on this. This controls pretty much everything. Depending on your model, the defrost cycle can be adjusted to shorter cycles. Bypassing it would eventually lead to ice build up and a real mess to follow .
Feb 04, 2013 | Freezers
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
Whirlpool refrigerator type 2255A The problem I
check your defrost timer manually rotate it possible stock up or replace if damage check the resistance of your defrost heater if good the freezing is normal try to adjust it to the next level of adjustment then conduct observation. check also the thermodisc it is connected to sense the ice vulging of your unit that trigger the defrost heater and defrost timer observe unit.
Feb 19, 2011 | Whirlpool Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Freezer temperature went from 0 to 20 degrees farenheit and holding.I had the digital readout, alarm, and temp. setting go out 1 year ago and replaced with inside temp. guage. I have a warrnty on the...
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
Dec 25, 2017 | Kenmore Freezers
Freezer switces off sporadically after periods of 20 to 10 days.
If this is a frost free refrigerator have the defrost timing unit checked out. It may well be sticking in the defrost position.
Nov 25, 2008 | Freezers
Walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer water line frozen
Sounds like your defrost sensor is not working the sensor should return the fan running and cooling after it senses 50 degrees in the condensor housing unplug the sensor and check if it shows a closed circuit. First unplug the freezer for your safety
Let us know what you find.
Sep 30, 2007 | Beverage-Air Freezer K Series Reach in...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
