Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
I had to check a Kenmore selfclean range-model# C97068842800.I replaced the oven sensor&the electronic clock.Oven temperature was-25degrees according to my tester than what was displayed on clock.Customer still complained that baking wasn,t good on bottom(had to flip pizza).Bake & broil elements tested okay.I,m not sure what else could cause her problem with baking? Range is not even a year old. Rene
  • Rene Matz Apr 28, 2010
    that range is an electric one. Rene
  • Kenmore Master
  • 8,220 Answers
Electric or gas fuel
Posted on Apr 28, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster Apr 28, 2010
    I think it is a weak ignitor. If it takes more than a minute or two to light off or look pale orange it is a has been. Take a look see:
  • Dan Webster
    Ok skip the ignitor theory. I would be looking for a bad circuit breaker or loose connection. You must be a tech. good luck with that one. LOL
  • Dan Webster
    Dan Webster Apr 29, 2010
    Thanks
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Oct 08, 2008 | Kenmore Kitchen Ranges
My kenmore elite oven is giving me a F30 error message. what is this code?
Sorry to read about your problem, I hope this helps you out.
f 30 is a the oven temperature sensor open, thats the probe in the oven area
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 | Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kenmore Electric oven 91141065791
Failure
Code
Condition Check/Repair F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC) F3 Open oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F4 Shorted oven temperature sensor Check wiring harness, replace oven temperature sensor if necessary F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC) F7 Computer logic interrupted (lock motor) Replace Electronic Range Control (ERC) F8 Computer logic interrupted Replace Electronic Range Control (ERC)
Oct 23, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
