Question about GE JRP15 Electric Single Oven
Reading a F7 code
The oven was not in use and started beeping. I went to it and seen an F7 code and pushed the off button and it stopped. About 2 hours later i preheated it and about 15 minutes into baking it did the same thing. Now it keeps coming back on with the same code.
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Ge oven JTP15 beeping and flashine F7 error
Jun 17, 2009 | GE JTP15 Electric Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
Beeping and F7 when cleaning
F7 stuck keypad
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
GE JRP15 Electric Single Oven Logo
198 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
