Question about Brother IntelliFax-2820 Laser Fax
I PUT THE BRAND NEW TONER CATRIDGE AND THE ITS PRINTING WITH TOO MUCH INK .ITS ALL DARK ALL THE FAXES OR COPY IS COMING TOO DARK.SO WHAT IS THE PROBLEM
  • 16 Answers
THE DRUM UNIT NEEDS TO BE REPLACED.
Posted on Apr 28, 2010
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
DIRTY COPIES BOTH SIDE OF PAPER
don't always believe what they say. just because its "supposed to " last a certain amount of time, doesn't mean it will. Once you get the insides dirty, its hard to get them straight again. Sometimes there is build up on the printer head from a leaky cartridge. I'm just guessing cause I had a similar brand that was brand new act up on me and because I was printing bold it started rolling the paper. I put it on economy printing to save toner and after a few runs, it cleared up. plus using a watermark helped but don't think that will help you in your situation.
Sometimes when I get a streak on one side its from light coming in from somewhere and it thinks its part of the image and prints it. If you make sure that your material is flat and not allowing light to come in or its firmly against the glass it might help.
Feb 20, 2014 | Kyocera Km-1820 Copier Fax Machine
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
Canon mf 6540 copies come out uneven
Did you clean beneath copy glass ( adf copy glass and platen )?Did you clean scaner also?
Clean the laser unit.
Not genuine toner isnt best solution.
Try to print something.If the print is OK, then the problem is in copy glass and scaner.
Jul 02, 2010 | Canon ImageClass MF6540 Copier
The left side of documents received do not print. How do I correct that?
I've checked my 3055 service manual and do not see this particular error as you've described it; I do have a couple of suggestions which may be helpful.
Since only half the page is printing, this implies an error with the print cartridge itself, it may either be low on toner or it may be damaged.
Does this error occur when you are printing documents from your computer or making copies as well? or does it only occur when you are receiving faxes? If the error is occuring regardless of what you are printing (or copying) and from received faxes I would have to conclude an issue with the toner cartridge itself.
You can visually inspect the cartridge by pulling back the plastic cover part and see if the roller shows signs of damage. If so, replace it.
Try shaking the catridge back and forth to even out the toner inside; If the cartidge is low on toner it's possible that what remains is only on one side.
Inside the printer, below where the cartridge sits is a black colored, somewhat spongy roller. This is called the transfer roller and if it's damaged it could be the cause of your print quality error.
Lastly, I would try a new HP cartridge, stay away from the generic brand ones as they tend to have a much higher failure rate and do not come with the HP warranty.
I hope this helps!
Sep 01, 2009 | HP LaserJet 3055 All-In-One Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Apr 01, 2009 | HP LaserJet 1200 Printer
Put in brand new toner machines says toner is low.
plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
119 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
