Question about Bosch 24 in. SHU43 Built-in Dishwasher
Shu43c06uc was running and then just stopped. No power at all when door is closed. I checked breakers and outlet is hot?
  • Bosch Master
  • 2,605 Answers
Hi Danny, since you've indicated the plug-in for the machine is "hot" then obviously the breaker is good, soooo. I would start by first going back and shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on Apr 28, 2010
Dedicated 20 amp outlet
Ideally you should run the line straight from the circuit breaker out to your hot tub, but if the line running from your circuit breaker to the box you're using now is 20amp. you can absolutely connected to that. to be up to code it cannot be an open box it needs to be closed After you wire in your 70ft connection. (that's assuming the box that you're using is dedicated already to your hot tub) then the only difference would be is your using extra line and costing you tenths of a penny extra and electricity per hour.
Jul 27, 2013 | Electrical Supplies
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
I have bought a corrina microwave and it is not getting hot what could be the problem
HELLO.
Thanks
Sep 18, 2011 | Microwave Ovens
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
The door is locked, no light on, washer won't run
Is the power cord plugged into a grounded 3 prong outlet?
Plug power cord into a grounded 3 prong outlet.
Are you using an extension cord?
Do not use an extension cord.
Has a household fuse blown, or has a circuit breaker tripped?
Check to see if a household circuit breaker or Ground Fault Circuit Interrupter (GFCI) outlet has tripped. If so, reset the circuit breaker or Ground Fault Circuit Interrupter. If the washer is on a fuse box, check to see if a fuse has blown and replace it, if necessary. If the problem continues to occur, call an electrician.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not operate properly with only one incoming source of water.
Is the water inlet hose kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove the inlet hoses from the washer. Remove any accumulated film or particles. Reinstall hoses, turn on water and check for leaks.
Is the washer in a normal pause in the cycle?
The washer pauses for about 2 minutes during certain cycles. Allow the cycle to continue. Some cycles feature periods of tumbling and soaking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look closed, but may not be latched. Open the door and close firmly.
Are the shipping bolts removed?
All four shipping bolts must be removed from the rear of the washer before you operate the washer. Each unit is shipped from the factory with four bolts, which are designed to protect the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration, error codes and possible machine damage.
Has a cycle been selected, but Start has not been selected and held for 1 second?
Press and hold Start for 1 second.
Is the Control Locked status light on?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Is the Delay Wash status light on?
Your washer will start after the selected hours of delay are completed.
Was the door left closed after the last cycle?
The washer door must be opened and closed again to start a new cycle. If the door is not opened between cycles, the washer may not start.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet has no power
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH5500B FL Washer
Washer Stops
• Plug cord into live electrical outlet.
• Check fuse or reset circuit breaker.
• Close door and push the start/pause pad to start the clothes washer. For your safety,
washer will not tumble or spin unless door is closed.
• This may be a pause or soak period in the cycle. Wait briefly and it may start.
Check screens on inlet hoses at the faucets for obstructions. Clean screens periodically.
If the sreens are colged or even a little sirty it will stop the washer!
Won't fill
• Be sure the door is tightly closed.
• Plug cord into a live electrical outlet. (Tub light should illuminate).
• Press the start/pause pad.!!!!!!!!!!!!!!!!!
• Turn both faucets on fully.
• Straighten inlet hoses.
• Disconnect hoses and clean screens. Hose filter screens may be plugged.
• Open and close the door, then push the start/pause pad.
May be a bad door sensor!!!!!!!
Huuum
Pleae remember to leave a rating
Oct 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
AFTER 10 MIN OF TURNING THE HEATER ON OUR POWER OUTLET TURNS OFF WHAT COULD BE THE PROBLEM?
Not knowing what kind of heater this is, I will assume that you are referring to a small plug in 110 volt room heater since you mention power outlet. Check the amp rating of your heater verses the breaker. Remember if it is a wall plug that there are other plugs on the same breaker. Breakers work two ways, as an over current (amps) and thermal protection (heat). It could range from too close of a current draw for the breaker and heating it up or a loose wiring connection at the breaker or wall plug. Loose could also be the problem for a central unit. After it runs a while place your finger on the front of the breaker to see if it feels hot, it should not get warm
Apr 25, 2008 | Heating & Cooling
Bosch 24 in. SHU43 Built-in Dishwasher Logo
175 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
