Question about Compaq Presario 2570US Notebook
I just replaced the LCD on my Compaq Presario 2570US. There appears to be a sync problem. There are short, thin horizontal lines at the right edge of the display and wherever the image changes (i.e. the left side of an icon on the desktop). Changing the screen resolution does not help. The service manual mentions a service program that must be run after the LCD is replaced. The service prog is not available to the general public at the HP site. Could it be a cabling/routing issue? I am considering tearing it down to verify everything. Any ideas?
  • 476 Answers
I beleive you have killed an IC chip.
please check my tips and tricks on this link
http://www.fixya.com/support/r4540660-replace_acer_laptop_lcd_screens
it explains in detail what you should have done from the beginning to end,
Thanks and please rate me MISTERDJ
Posted on Apr 28, 2010
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My Compaq presario CQ42 has a white-red thin line at the right corner of the screen. Is it a problem to use the laptop with it before I fix it.
@tharindupedu
If you see a Vertical/Horizontal colored lines on your LCD, that means either the Video Card, LCD, or the LCD Flex cable (this is the cable that connects your motherboard to your LCD screen) are going bad and needs replacement. You can still use your laptop though but I strongly recommend having it fixed ASAP before it gets worse. You're still under warranty, call HP/Compaq at 1-800-652-6672.
Good luck.
Sep 07, 2011 | Compaq Presario M2000 Notebook
How to replace backlight on compaq 2570us laptop
What is wrong with the backlight? The computer screen is just dark? I would start with the inverter. The inverter is usually the problem when the screen goes dark but people think it is the backlight. The backlight alone is very hard to change too. Go with the inverter, I would bet that is the issue.
Apr 02, 2010 | Compaq Presario 2570US Notebook
Horizontal flashing line at the bottom of screen
I am sorry but, usually, that is the start of the screen's LCD failing, it will most likely get worse over time... This is caused by the "Driver" transistors failing....
Mar 07, 2010 | Compaq Presario Notebook
Very thin vertical red line just appeared on my monitor. It is about 5-6 inches from left side.
LCD is starting to go bad. Anytime lines start appearing randomly or constantly, the pixels are going bad so the screen needs replacing.
Nov 30, 2009 | Compaq Presario M2000 Notebook
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
Blue thin vertical line on my monitor.
LCD needs to be replaced.
Common problem called "Tab separation".
Mar 22, 2009 | HP Compaq Presario R4000 Notebook
Yellow vertical lines on the screen of my DELL inspiron 9300
The pixels are shot - common for lower priced LCD monitors. Once it starts, it will continue. Theres no inexpensive fix for it - time to retire the Compaq
Nov 28, 2008 | Compaq Presario M2000 Notebook
Thin yellow line on the right of the LCD Screen
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Compaq Presario 2570US Notebook Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
