Question about Canon PowerShot A85 Digital Camera
Screen is washed out
The LED viewing screen no matter what mode, looks like flat stick was pulled across a wet color painting and does not change.
  • Canon Master
  • 3,083 Answers
Most likely the LCD Screen is broken, that's one of the ways it looks when it's been broken. It will need to be replaced. Sometimes you can find them on the net, and sometimes you can find an "as is" camera on ebay for a few bucks, and salvage it's screen. There are many articles and even videos about how to change the screen on the net. Get an estimate before you get it repaired. The cost of repair can exceed the replacement cost of a new camera. Good luck, hope this helps!
Posted on Apr 28, 2010
Need advice on color issue with Samsung UN46EH6000F TV
The TCON board or the LCD panel is Faulty , Can confirm by replacing TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | Samsung UN46EH6000FXZA 46 1080p 240Hz LED...
Im wanting to paint my out of house like the trim but i have car paint that i mixed half house paint and half car paint will that matter
Yes, it matters while this is not suitable to go with. Because it will not mix perfectly that you can go for either your house or your car.
im-wanting-paint-out-house-like-trim-but-i0bi5i5c5y5upqwvylbf2zfm-1-0.jpg Oil Color Paint:
Da Vinci Artists Oil Color Paint Display
May 05, 2015 | Tools & Hardware - Others
HOW COME DOES MY SHARP LC39LE440M LED TV HAVE VERTICAL LINE ALL ACROSS THE SCREEN?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 10, 2014 | Sharp Aquos Televison & Video
Horizontal lines LED hisense tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Hisense Televison & Video
What is a paint stick?
Paint sticks offer a different way to work with oil paint. Rather than using a brush, you hold the paint stick in your hand to create different lines or textures than you could with a brush.
Feb 03, 2013 | Crafts & Hobbies
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 26, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    Washed out colours and thin red lines across the screen
    your problem is in red video circuit. please get it done with skilled tech.
    Oct 05, 2007 | Panasonic CT-32SL15 32" TV
    My LCD screen shows a colorful vertical line & then the screen goes white
    Hello, The problem is in bad contacts on flat cable from the LCD. Cleaning the cable and the connector can solve the problem. If you need more info please advice. ps: this should be the long term solution.
    Apr 21, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
    No red color on screen
    sounds like you cracked the printed cuircut board on the crt drive board or in the video cuircut.. If you know how to solder look very carfully with thw set unpluged for crack on the crt pcb or the main board then scratch off the paint on the little pc traces on both sides of the crack and solder a wire across the trace
    Apr 02, 2006 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
    Canon PowerShot A85 Digital Camera Logo
    144 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
