Question about Samsung DV448AEE Electric Dryer
No heat cleaned vent and left it off still no heat
  • 784 Answers
Heater element needs to be replaced.
Posted on Apr 28, 2010
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Fisher Pakel dryer wont heat all the time
open round housing on left inside where the lint catcher is. clean it. if that not solve your problem then replace reset switch. hope it will help you.
May 01, 2017 | Fisher and Paykel DEGX2 Dryer
I have an MPI monitor heater model gf 1800. It keeps flashing E17. why?
My GF 1800 was flashing the e17 code as salenski_mar said.If all is clear around vent pipe, sufficient fuel in tank,ect. take the front cover off the unit,2 sheet metal screws on bottom side left and right(remove power first)on the left side of my unit there is a round black barell shaped container called a heat exchanger.Located about halfway up a small panel with 2 white tube shaped wires going into it.remove 4 screws on this panel and remove the panel.
There are 3 electrodes here . carefully clean these with a rag or fine sandpaper.
Reassemble and retry the heater.I watched a heating tech do this to my unit and charge me $75.00 last year.Did it again this year and I saved a service call.Actualy I believe he used a $20.00 bill instead of sandpaper but clean the flame sensor and it may work.worth a try.
Sep 22, 2012 | Rinnai Toyostove Direct Vent Heater: Laser...
Dryer will not keep constant heat
clean your vent that goes out side Thats what does that the hot air dosent go outside but comes back on the temperature control and shuts the heat off. Also if you put wet close it it the lint will be built up behind the fan. You have to lay the dryer down take the back off and fron the bottom on the left side is the vent foller the hoe to the left. there is four 5/16" screw hokling that tub on thake those screws out and raise that unit enough to get you hand to the fan blades and you will find two hands full of linte matted there.
clean that out dryer need good air flow be sure to pull youi vent out the top and clean before each dry.
Apr 21, 2010 | Whirlpool LGB6300 Gas Dryer
No longer gives out heat
your heating element is probably bad but this happens for some reasons. main reason clog in the vent you may need to get a chimney cleaning company to clean your dryer vent or do it yourself. another thing a dirty vent will do is trip the heat sensor. this heating sensor probably is the only thing broken if your vent is very dirty
Apr 09, 2010 | Dryers
Shuts off
EE12 is an over heat condition. Clean the screen on the back of the heater and restart. Error code are explained on the lower left side panel.
Tom Hawkins
Bethel, Alaska
Feb 02, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Jan 03, 2009 | LG DLG5932W Gas Dryer
Whirlpool gas dryer runs but won't heat
hi stella. yes the problem is with the thermal fuse. when you were cleaning the vent at the left. the thermal fuse is right there, on the air duct, a small piece of plastic with 2 blue wires to it . replace the thermal fuse . thanks the appliance doc
Oct 06, 2008 | Whirlpool LGR7646E Dryer
Whirlpool gas dryer GGQ8858KQO won't heat
hi thanks for the question .the problem you have is with the thermal fuse. located at the back. remove back panel . on the air duct, on left side, you will see a small plastic piece, with 2 blue wires to it. replace this part. and clean all air venting to the outside. as dirty vents can cause the thermal fuse to fail. thanks the appliance doc
Sep 29, 2008 | Whirlpool LGQ9858PG Gas Dryer
Kenmore model 110.64672400
Yes if it taking long to dry the vent is still resticted. Thats all it can be! Nothings wrong with your dryer! focus on the vent and you will fix it!
Dec 01, 2007 | Kenmore 63942 Dryer
Samsung DV448AEE Electric Dryer Logo
204 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
