Question about Brother HL-2070N Laser Printer
Brother HL 2070n
Drum light was on and replaced the drum. I did the reset and the drum light is still on. I did this again and the light is still on. Costly as that was I bought another drum and toner and still the drum light is lit! I really do need help with this Please.
    Sergeant:
  • 406 Answers
Check the website of brother. If they allow you to download and update its firmware. Update the firmware and driver as well.
Posted on Mar 24, 2008
Need help resetting the drum on HP 2070N. Drum is changed. Light is still on. Thanks!
You need to have the front of the printer open, when you press and hold the "Go" button. All four lights will come on, in sequence. Release the button, and close the front cover.
Oct 07, 2009 | Brother HL-2070N Laser Printer
Drum light still on when toner has been replaced
You need to replace the drum and reset the printer for that to go away, open the front door and hold the go button til all lights flash and the drum is reset. If quality is OK you can keep using the old drum. If you press the go button 3 times it will give a report showing the life left in the drum.
Oct 01, 2009 | Brother HL-2070N Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Replaced Drum in printer won't print
Unplug it then plug it back in and check for anything in the device. Or leave it unplugged for a few hours and try again.
Apr 16, 2008 | Brother HL-2070N Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Toner light still on after replacing with a new one
Drum counter usually has to be reset.. Check user manual or go to Brother's site if you want to drive yourself crazy Ed
May 04, 2007 | Brother HL-2070N Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Logo
309 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
