Question about Keurig B60 Coffee Maker
Coffee won't pass through pod
Th coffee gathers in the area just above the pod. Only a very small quantity goes into the cup. I cleaned the removable cup but this didn't help. The used pods only have one hole on the bottom. I called Keurig and they had me stick a paper clip up the three holes on the lid. Still doesn"t work I suspect that the device that punctures the pod isn"t going down far enough but I can't tell why.
    Sniper:
  • 92 Answers
The K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Posted on May 06, 2010
I keep getting small cups of coffee.
I have one of these coffee makers also and having the same issue. The machine is getting limed up. Run some vinegar through it. What I found also a little trick is to turn the machine on, place a cup underneath like you were brewing a cup and press the brew button. Let the remaining water come through and the next time you will get a full cup. But this does not solve the issue. Liming seems to be the issue with these makers.
May 14, 2016 | Keurig Coffee Makers & Espresso Machines
Stop a whole litre of water going through each time i put a pod in.
The way to program the quantity of water is to press & hold the button you are programming until the amount of water you want is in the cup, then release it. Next time you make a cup with that same button with a single press this time it should cut off with that same amount in the cup. If that doesn't work then take it back, that is what a guarantee is for.
Jan 25, 2015 | Krups Coffee Makers & Espresso Machines
My nespresso machine stops long before it should.
Most Nespressos that I have worked on have an auto programme function. Put the pod in and a cup under it, press AND HOLD the button down until desired quantity is in the cup. Release the button, that should programme it to deliver that same quantity next time.
Oct 17, 2013 | Coffee Makers & Espresso Machines
Using the k-cup..does not brew the water splashes everywhere
That is because most likely the part that punctures the k cup is most likely clogged, try using Like a paper clip and cleaning out the small hole and should flow. Mike
Oct 29, 2011 | Breville BKC700XL Stainless Steel
The coffee coming out is too long and is getting progressively longer! We can no longer make a short coffee.
Goodmorning,
First you should adjust the level to place the cup on, once you did it, there is a pommel in the center of the machine, that regulates the lenght of your coffee (small cup icon is ristretto/small quantity on the left and big cup icon is lungo/big quantity) you just have to turn the pommel on the lenght desired.
Good work!
May 31, 2011 | Saeco Odea Giro Plus Coffee Maker
The water or coffee does not come out correctly anymore. When making a cup of coffee (w/ pod) or just hot water (no pod), the hot liquid does not come out in a steady stream, it goes everywhere. When i...
211333Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
Water does not seem to be getting to the heating area
I'm not sure if your saying it does not brew a cup of coffee at all or it is brewing but only cold water comes out. If it is just sitting there making a whinning noise and not delivering water it may just be dirty. To clean it you need to fill the resivior with a 50% white viniger and 50% water mixture. Run a brew cycle and let it sit for an hour. Then run several cycles through until it is out, refill the resivior with water only, run it completely through and continue with the water only until there is no more viniger smell or tatse. You will need to clean the brewer needle heads as well. Lift the handle to access the coffee pod compartment, remove the pod basket and use a paper clip to clean out the hole in the puncture needle. With the lever still raised, use the paper clip to clean out the three holes in the upper needle head. Replace the pod basket, close the handle and run a couple brew cycles through without a coffee pod.
Nov 24, 2010 | Keurig B100 Coffee Maker
Water does not pass through the Mr. Coffee. Just started out of the blue a few days ago. Heating element definitely works as steam just pours out the back of it but after running for 15 mins or so only...
Most of the time the coffee maker just needs cleaning with some Vingar sulution run though it.Do this about every 6 mouths.what happens specially with hard water it cluggs line up.So go to store buy small or big bottle of Vingar put about 1 cup in and half cup water aloud it to go though cycle's.Then or you may put two cups of vingar and two cups of water depend on how clugg it is.Then after done fill water despenser up to run Full pot like 12 cups,but donot over fill.that cleans it from the Vingar taste.You may want to do this twice.Hope this help,thanks for your question it was a good one.
Aug 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Water goes into bottom tray
One possible problem is to try to clean the group shower which it can be ansrew by one center screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Both the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
One other posibble problem is the vibrating water pump. It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
May 16, 2010 | Krups XP2070 10 cup Coffee Maker/15 bar...
Saeco machine - only produces a small amount of coffee
Remove the brew unit and look at the top where the spout leaves the top piston(red oring) you will notice a small tube being held down with 2 screws, remove screws and carefully lift tube, and remove spring and white plastic ball(do not lose ball). Clean that chamber it will be blocked with coffee grounds. Re-assemble and try machine.
Jan 25, 2010 | Coffee Makers & Espresso Machines
Keurig B60 Coffee Maker Logo
1,321 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
