My washer won't do the final spin
I have a ge whre5260e1cc that won't perform the final spin. It appears that it would start but suddenly it stops.
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 28, 2010
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
WASHER WON´T WASH OR SPIN
Hi
Sounds like a lid switch issue to me. the washer wont run if it thinks the lid is open. its a safety mechanism. Replace the lid switch. it's a cheap try and probably the right answer
Dec 10, 2008 | GE WPGT9360EPL Top Load Washer
My washer wont do the final Fast Spin
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Do this - I had the same problem and this fixed it. It takes about 10 minutes.
Oct 27, 2008 | GE WSXH208A Front Load Washer
GE Washer does not reach full spin speed...stops abruptly
HI thanks for your question. the G E washer has to get rid of all the water before it starts to spin. check to see if you have a good water flow on pump out. if not clean the pump . thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | GE Washing Machines
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Washer stuck on final spin cycle
when i start my washer it stays on the spin cycle
any tips on what might be the problem
Apr 06, 2008 | GE WBSE3120B Top Load Washer
Final Rinse
im a repairman and just ran into that same problem on the ge washer. the problem is the control board. That control board is expensive, but it will fix the problem
Feb 02, 2007 | GE WJSE4150B Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
