Question about Apple Studio Display 17" LCD Monitor
Apple monitor Not sure if if the monitor is worth repairing The light is flashing every few second from the bottom appears to be getting a little darker thanks
    Genius:
  • 1,913 Answers
I THINK YOUR DISPLAY COLOR PROBLEM.
DEGAUSS YOUR DISPLAY, CHANGE YOUR DISPLAY COLOR RESET IT TO DEFAULT SETTINGS.
Posted on Mar 24, 2008
I have a blue screen on my hisense tv and when I turn on the power the little light on the bottom flashes 7 times and then 3times what could this mean?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 26, 2014 | Televison & Video
Screen will not start - blue light on LG start up flashes on and off about every second? Not the pc backup screen is fine - is it fixable?
check the monitor on a differant pc or laptop to make sure the problem is the monitor. Unfortunetly unless the monitor is under warrenty it isn;t that cost effective to fix. The price to repair will be as much as a new monitor.
The parts are cheap but the labor isnt. So if you can find some to look at it get an extimate and know what a new one is worth before spending any money.
Mar 23, 2010 | Computers & Internet
No display on Viewsonic VA1912wb
Your monitor sounds like it has gone bad. Cost for a repair is not worth it, a new one would be cheaper. Prices have gone down a lot in three years
Sep 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Lcd monitor goes black
Try a different monitor (a friend's) on your computer, if it works OK the problem may be with your monitor. If it does the same as on your monitor, the computer video card may be defective.
Try your monitor on a different computer (a friend's) etc. You will figure if anything or what is defective. Then you can decide to repair or replace.
May 31, 2009 | Apple Multiple Scan 1705 Monitor
Fujitsu-Siemens P15 TFT power/picture problem. it take time to turn on.
It does indeed sounds like the capacitors, I had this problem last year with a Medion monitor where it would turn on and off, when I spoke to Medion they did say that it would need a repair but at the time I wasn't enclined to pay the repair fees for something that may happen again!
Personally I would stick with your plan of getting a new monitor because my view on monitor hardware issues is that if it's happened once it will happen again even if you do repair it resulting in a lot of hassle!
May 27, 2009 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Hit power button the screen flashes on for a second then goes black again.
I just repaired one.... will likely require that you replace 3 X 220 uf 25 volt capactiros and 2 X 1000 uf 25 volt capacitors. can't miss them the tops are swelled up. but the monitor appears to work now... not bad for 5 bucks worth of parts.
Apr 03, 2009 | Acer AL2017 20" LCD Monitor
Acer AL 2017 Monitor
Sep 10, 2008 | Acer AL2017 20" LCD Monitor
Flashing padlock icon in the middle of the screen
When the icon is in the unlock position, hold down the Menu key (the far left button in the lower righht hand corner) on your monitor. This should bring up the menu. From there, you can reset the factory settings.
Mar 16, 2008 | Dell E172FPt 17" TFT LCD Flat Panel...
ViewSonic VA721 monitor
this is only an educated guess based on my years of computer and electrinics experiance. I believe the problem is the AC inverter that supplies current to the monitors back light,it powers up and fails. the monitor is working but without the back light you get a blank screen.The problem is fixable, but the delema is that for a technician to troubleshoot and repair the problem may cost as much as replacing the monitor since the prices have dropped so much in the last few years.
Dec 23, 2007 | ViewSonic VA721 17" LCD Monitor
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Apple Studio Display 17" LCD Monitor Logo
184 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
