Question about Kenmore 700 6972 Dryer
The dryer will not turn off and it is only 6 months old. The timer will not move from its setting and runs continuously. Dryer setting does not matter.
  • 45 Answers
The timer switch is bad. It is an easy fix. Simply unplug the power source. Unscrew the 4 to 6 screws from the insturment panel. The knob should pull off from the front. unplug the plug from the switch. Take it to sears parts department and order a new one. The part should not be over 35.00. Installation is the opposite of removal.
Posted on Apr 28, 2010
Timer switch faultynonnwhite knight 44 aw . Will work for a couple of months then not, then start working again for a while then not?
Motor in timer is stopping heats up stops needs new timer
also check even heat board or cycling stats if these stats do not open timer will not move also check for vent restrictions if dryer over heats can also be a issue send me exact model number or picture of Tag will be bedder
Feb 19, 2015 | Abbaka White Knight 44AW Electric Dryer
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Dryer will not turn off
May 20, 2009 | Dryers
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
A common problem, had it happen to me.
Replace the timer control. takes about 15 minutes and the skill to remove screws, disconnect plug from old timer, remove timer, install new timer, connect plug, replace screws and panel, run dryer.
Reply the model number, and I'll get you the timer P/N.
Jan 15, 2009 | Kenmore 97572 Dryer
Maytag dryer PYE3300AYW Continuously runs
jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
May 19, 2006 | Maytag PYE2300AY Electric Dryer
Kenmore 700 6972 Dryer Logo
481 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
