Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
The light bulb stopped working in our side-by-side refrigerator. We've replaced it with a new bulb and also tried a bulb that worked in our other refrigerator. Any suggestions would be appreciated (other than replace the bulb).
    President:
  • 1,335 Answers
Check the light switch in the door. It could be stuck in the off position.
Posted on Apr 28, 2010
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
Light not working in Maytag Plus 134A Refrigerator
Sure you've got power to the bulbholder? Check the switch
Sep 04, 2012 | Maytag Refrigerators
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
The light bulb burned out. I do not know what type and and wattage of the bulb to replace it.It is the refrigerator light bulb in GE TFX24R refrigerator. Thank you my email is endliamc@gmail.com
According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to give the best FixYa experience.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator light doesn't work
then tyr and replace the door switch on the refrigerator side. they are relatively inexspensive to buy and are real easy to replace.
Feb 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
202 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
