Question about Franklin RF-8110 192K Palm Style Touch Screen
Touch screen will not respond after resetting. what can i do?
Hi there my daugters ipod touch 8gb screen gone white and does not respond when you press the screen
You may need to reset. Important: Only reset your iPhone or iPod touch if it is no longer responding. To reset, press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
Jul 19, 2010 | Apple iPod touch
Touch screen stoped responding.
There is a reset button on the bottom of the unit. turn the unit off then pres in the reset when you turn it back on
Jul 20, 2009 | Computers & Internet
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
Jul 30, 2008 | i-mate JAM Pocket PC
Touch screen not responding.
Is there anything on the screen?
try to perform a cold reset by plugging the battery out
Jul 22, 2008 | HTC Touch P3450 Smartphone
Treo 600
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus4.gif.
Jan 01, 2008 | Palm Treo 600 Handheld
Touchscreen does not respond to touch
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Dec 11, 2007 | Palm Treo 600 Handheld
Touch screen is not responding with the stylus
Try do a hard reset to your device to the deafult vendor definitions, then re-initilize the screen and this should help.
Nov 12, 2006 | Toshiba e330 Pocket PC
Franklin RF-8110 192K Palm Style Touch Screen Logo
19 people viewed this question
Top Franklin Computers & Internet Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
t d
t d
Level 1 Expert
Are you a Franklin Computer and Internet Expert? Answer questions, earn points and help others
