My messenger will not start saying error code81000306
    Guru:
  • 571 Answers
Error code explanation and possible solution Error code 81000306 usually occurs when there is a problem with the .NET Messenger service. one or more of the servers providing it might be down or having problems, with as result that you can no longer sign in. This normally won't take longer then a few minutes/hours. For more information you can check the .NET Messenger Service Status or our own forum.
This is how the Service Status looks with a normal situation
Please note that the Service Status is known to not always be very accurate, if problems do appear the best thing to do is wait them out. Surely there are many other very interesting things to do. If the error keeps bothering you for over a few days there are some more things you can try below.
Other steps that might help It may also indicate you have a proxy server or firewall on your network that does not allow incoming connections to Messenger. This is usually the case in companies or schools. Ask the network administrater how you can use Messenger and if they will allow it. You can also use a web based messenger in this case (if these sites aren't blocked by the network administrator). See our links section for webbased messengers.
Posted on Apr 28, 2010
  • 4,924 Answers
Just uninstall it completely from the control panel add remove programs ...than go to my computer /Cdrive/program files and look for yahoo...and inside remove the messenger folder (same with the MSN if it is the case) ...in this moment you have removed all trace of the old program inside your computer ..and just reinstall it clean ...from the original site ..Here is the link ...just download and install...
I forgot to mention ..if the program starts but just refuse to sign you in ..there can be a problem with your account ...and it is either blocked cause someone tried to break your password and failed too many times(this will be back in 24 H ) ...or it is teh server ..and you also have to wait fo rthem to solve problems ...but if it is the program itself that do not starts ..than do what I just explained...and reinstall the program ...from scratch ..cause it is damaged..
Here is the link for it ..
http://messenger.yahoo.com/
just download and save it on desktop...than double click on it to start the installation ..and follow the instructions ..
I have Yahoo mail and Yahoo messenger on my phone. I can communicate by SMS to someone's phone or by IM to someone's messenger. When I try to sign in I get an error message. How can I fix it?
I've been having the exact same problem - which appears to have started at the same time as yours! I can't find how to fix it anywhere!
Dec 12, 2011 | Yahoo Messenger
I am unable to download yahoo messenger , it is saying an error when it start downloading "check the firewall settings"
Try to download the yahoo messenger from this link given below.
Yahoo messenger
Or
Let me know if this works.
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 18, 2010 | Yahoo Messenger
Messenger
File errors after copying or downloading the messenger try to download another one and install.
Apr 29, 2010 | Yahoo Messenger
Trying to download yahoo messenger but I get an error that says something like this: applications has failed to start because the application configuration is not correct. Anyone have an idea why its doing...
Check it out with down loading installation path and as well previous versions of YM on your system along with other Messengers with out error
Dec 12, 2009 | Yahoo Messenger
I cannot sign in my Yahoo Messenger it always says log in error 81003004. What to do?
if this just started, it is more likely a yahoo server error. try to clear the temp internet file, cookies (browsing history) and make sure the date and time settings of your computer is correct, then restart your browser and try yahoo mail again
Nov 24, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Error # 13
What "Messenger" are you trying to use? I'm not familiar with "SweetIM".
Strongly RECOMMEND:
Use MSN Messenger, Yahoo Messenger, Google Messenger, AOL Messenger, OR a well Known and Used Instant Messenger with Better Security and SUPPORT!
Jun 12, 2009 | Computers & Internet
My Yahoo Messenger is not working at all
try remove any program that associate with ym like dekstop smiley or etc
Dec 02, 2008 | Yahoo Messenger
Yahoo messenger problem
you might have installed third-party plug-ins, audibles or emoticons on your yahoo messenger. these programs are automatically loaded everytime yahoo messenger starts. they work fine, not until you reinstall yahoo messenger or upgrade it to a newer version causing an internal error when they are loaded. first, remove/uninstall all these programs from the add/remove programs in the control panel, be very careful when doing so and be very sure of what you are removing. then uninstall yahoo messenger. if error still occurs during the uninstallation process, you haven't removed every program/emoticons/plugins connected to your yahoo messenger. when uninstallation is successful, restart your computer and then delete the yahoo messenger folder in the programs folder on your system hard drive. then you can reinstall yahoo messenger before adding/installing your emoticons or plug ins again.
Oct 01, 2008 | Electronics - Others
Messenger
driver display can't used for notebook acer 4315 email : jalmi_ganteng@yahoo.co.id
Aug 11, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
