Question about Nikon D70s Digital Camera
How do I display the count of photos in the top display screen
  • kakima May 11, 2010
    What's appearing there now? Is the camera connected to a computer?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Jun 02, 2010
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
If I set my Nikon D90 on "macro" it will NOT take a picture and in the box that displays the photo count on the top of the camera, it give reads "r18"
Once you set your camera on macro, it will only fire within a certain range of distance. You may have to move in or out to determine that distance or consult your manual.
Oct 25, 2010 | Cameras
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
I have a Dell W5210n printer that I replaced the fuser on. How do you reset this printer?
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
(answer previously provided on fixya.com by ramrui)
Jan 04, 2010 | Dell 5110cn Laser Printer
How to reset maintenance counter on a Dell 5310
Jul 21, 2009 | Dell 5110cn Laser Printer
File Error now shows in camera for rotated photos from PC.
The camera will not display photos that have been edited by something else. Rotating counts as editing. Just opening a photo and then saving it without doing anything else counts as editing.
Apr 29, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Page count
Press Function,Dataregistration if user settings is displayed on the screen ,press # button.1 sssw will be displayed on the screen.Use the arrows to scroll down to "printer" press set or ok and scroll down till you get print count press ok or set.
Mar 09, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Setting print count on Lexmark T644
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Dec 17, 2008 | Lexmark T644dtn Printer
Nikon D70s Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
