Question about Toshiba 50A60 50" Rear Projection Television
Toshiba 50 After 5 years of loyal service my Toshiba 50" just sharted to have a 3-d effect of red and green.
  • bmass29 Mar 26, 2008
    Where do i get the parts for the tv?
  • Toshiba Master
  • 8,617 Answers
Your convergence ICs need to be replaced. Its an easy and cheap repair if you can solder. Parts will cost about 20.00 for both ICs
Posted on Mar 24, 2008
  • Sonny Berry
    Sonny Berry Mar 27, 2008
    www.electronix.com will have the ics you need. just look in your set the two ics will be on a large aluminum heat sink with STK numbers such as STK392-110 or similar.
Added wrong coolant 50/50 to my 2001 grand am what will happen
Hi Damita:
Shouldn't be a cause to be overly concerned.
My questions to you:
- Why did you have to add coolant, and "just because it was low" is not the answer.
- What kind of coolant did you add, and why do you think thay it is wrong?
If the engine overheated and that's why the coolant was low, we should be trying to discover why the engine overheated. Things like Bad Water Pump, blocked radiator, bad thermostat, blown head gasket.
The coolant level is the indicator that something else could be a problem.
Hope this helps.
Jun 22, 2015 | Cars & Trucks
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Color appears out of alignment. The set has
Replace the STK392-110 Convergence ICs and the 6 1.8 ohm 1watt resistors. You can get the repair kit whcih also contains the instructions from www.tvrepairworld.com
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
My panasonic lifi tv starts flashing green then the red light flashes red all the time now.
If the light is flashing 2x and pausing and repeating you probably need a new lamp.Panasonic has extended the warranty on the labor for the lam p to 3 years due to difficult replacement.Call Panasonic customer service and they will refer you to the nearest service center.The lamp itself is covered for 5 years.
Nov 10, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Toshiba 50hp66 The tv shuts off and the red light
Sounds like a system failure - one of the controller boards may have gone bad. If the unit is still under warranty, contact Toshiba for warranty service. Otherwise you will need to contact one of the authorized service centers or your local TV repair guy to arrange for repair.
Nov 08, 2009 | Toshiba 50HP66 50 in. Plasma Television
Faint red blotches visible on light backgrounds on Sony KDF-42WE6
Convergence issues usually present as colors not lining up or a sort of "3D" effect like when you had to wear the green and red glasses. I'm no expert but it sound like you may have a magnetizing issue. You can test this by placing a large, very strong magnet on the "blotchy" area.
Slowly move the magnet in an ever widening circle. Pull the magnet back off the screen about an inch once you have circled the entire blotch but continue to rotate the magnet. Do this for about 5 minutes. If you don't see any change once you may need a stronger magnet or this is not the problem.
I had the same problem with a 6 year old Toshiba 50H13 and I found this tip online somewhere. I used a half dollar sized, rare earth magnet. I noticed a change almost immediately.
Hope this helps
Will Banks
Apr 02, 2009 | Toshiba 50H81 50" Rear Projection...
Red double picture with green and blue
convergence problem there are 2 integrated circuits inside the set needs to be replaced
Aug 25, 2008 | Toshiba TZ50V51 50" Rear Projection...
Suspected Convergence Issue on Toshiba 51H83?
Needs chassis pull & convergence IC's replaced....then
Touch Focus will work again..................T.
Nov 19, 2007 | Toshiba 51H83 51" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Another Convergence Problem?
dont move the pic tubes that will be a costly mistake the problem is still your ics replace them all you should have two check for bad solder connections
Nov 12, 2006 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
