Question about HP Pavilion dv7-1130us Notebook PC
Plugged in & not charging with new battery
Notebook plugged in & not charging with new battery & suddenly shuts down. Or plugged in & the laptop doesn't recognize it's plugged in & the battery expires & shuts down
  • 185 Answers
Laptop not charging
if you have a brand new battery and it is not charging, check the charger you may have to replace the plug on both sides, check the cables.
you can take the charger to a TV repair shop and tell them to check it and see if there is any juice (charge) coming out of it. that is a common problem with chargers, we trip over the cable or pull it out of the laptop by accident and it brakes little by little. if there is no charge coming out you can star by checking the jack you may have to cut it and have them check it again.
if you don't want to go trough the whole testing, just tell the TV repairman to fix it it should cost you about 30 bucks instead of 80 for a new original charger or find a chinese one on e-bay
if it works for you don't forget to rate me
Posted on Apr 28, 2010
When i start my fujitsu notebook it appears and suddenly shutdown
Are the fans and vents free of dust? Unplug, remove battery, Try to reseat the Memory mods., plug in, reboot. When it shuts down, does the Battery charge LED stay lit?
Jan 19, 2013 | Fujitsu AMILO D-7820 Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
Laptop suddenly stops recharging / recognizing the charger
Here is a manual....mostly replacement parts etc.
http://tim.id.au/laptops/toshiba/satellite%20and%20pro%20220%20440%20460%20470%20480.pdf
Sounds like your battery is shot, bad or discharged or shorted batteries will shut the charging circuit off.
Oct 16, 2009 | Toshiba Satellite Pro 470CDT Notebook
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
Jun 04, 2009 | Toshiba Satellite M45-S269 Notebook
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Sudden Shutdown
bad capsisters on motherboard thx nick
Feb 10, 2008 | HP Compaq Presario V2000 Notebook
HP Pavilion dv7-1130us Notebook PC Logo
308 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
