Question about Hitachi lamp
I wonder if the lamp 29, one supply (DT00682(Lamp No.)
Toshiba big screen tv black screen with sound
It is telling you that you need a new backlamp or that the power supply that feeds it is out. It could be bad Chinese capacitors or you may actually need a back lamp. The hint was when it was working did the side edges have a darker brightness to them? If yest the lamp is needed. If no then the capacitors in the backlamp supply may have decayed.
Oct 01, 2012 | Toshiba Televison & Video
How to reset lamp time
Link
You can follow above link on how to reset your lamp time. Note that we can only reset time of lamp only when it is replaced. Kindly read page 29.
Thank you.
Aug 01, 2010 | 3M X40 Multimedia Projector
How can I tell if the lamp still works? I dont have the projector to text the lamp so I'm wondering if there is any way to tell if it still works.
Because the lamp does not have a filament, you cannot run a standard continuity test either. You really need the correct power supply and ballast to see if it still works. Many old lamps will continue to work although the lumen output will be significantly reduced.
Jun 28, 2010 | Panasonic Projector Lamp for PT-LB50...
Does not turn on and no LEDs
Lamp is not the problem , Power supply Board look for swollen puffed up capacitors.and if you still do not fine any bad power supply Board can be replaced CK ac Fuse.Call Encompass Electronics for Parts 1-800-638-3328
Sep 13, 2009 | Samsung HLN5065W 50" Rear Projection...
Can I reset my lamp timer without replacing the lamp?
That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
Mar 25, 2009 | InFocus IN72 Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
KDS 50A2000 red lamp light blinking 2 times
Did you use an original Sony lamp? If so, I would say that the problem lies with your lamp ballast, or lamp power supply. Also, keep in mind that, although rare, occasionally the lamp power supply will fail in such a way that it will take out the lamp and any other lamp that is put in. So if your new lamp is blown, it is likely the lamp power supply that is at fault and you will require a new lamp as well.
Dec 10, 2008 | Sony KDS-50A2000 50" HDTV
Sony VPL CS6 in darkness !
Make sure the interlock switch is activated by the cover of the lamp.
Can't measure a voltage with the lamp cover open. High voltage is powering the lamp from an smps or ballast supply. If lamp is New, cover switch is good, then the lamp power supply could be faulty.
Siliconchip.
Dec 29, 2007 | Sony VPL CS6 Multimedia Projector
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Hitachi lamp Logo
52 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
