Question about Sony SLV-775HF VCR
CAN NOT INSERT A TAPE WHEN POWER IS TURNED ON
CAN NOT INSERT A TAPE. WHEN POWER IS TURNED ON E3 01 APPEARS ON THE SCREEN.
    Guru:
  • 276 Answers
Sony VCRs have shown these error codes for years whenever a problem occurs but it really does not help much to know what the code means. Even if you knew the code meaning you still would not know exactly what to fix in the VCR. Suffice it to say the VCR probably needs repair.
Go to https://eservice.sony.com/webrma/web/index.do
and enter your zipcode to locate a SONY repair facility.
Posted on Aug 13, 2010
Tape Holder will not re-insert
See my post on here from yesterday, I explain same problem as you have on your camera.
May 28, 2010 | Sony Handycam CCD-TRV318 Camcorder
When tape inserted re insert tape and C 31:23 APPEARS
The camcorder has detected an issue that may require a power reset. To perform Power reset,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 04, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Hitachi Camcorder VM E220A - After load cassette "TAPE" error
There is a mode switch within the deck assembly that is probably dirty but not cleanable. I haven't repaired one of those for some years and am sure spares are no longer available for it. The 58 is V8 format and should be OK but may show similar symptoms due to age, in the future.
May 24, 2017 | Hitachi i.mega HDC-401 Digital Camera
Drawr problem with DAT deck
Tape transport is similar to VCR. Problem may be sensors needing to be re-soldered. Sometimes this will remedy erratic function
Feb 11, 2008 | Audio Players & Recorders
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS HOPE THIS HELPS.
EBEN
Dec 06, 2006 | Panasonic NV-DS29B Mini DV Digital...
Televison & Video Logo
217 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
