Question about Dometic Rooftop RV Air Conditioner
Roof leak from seal between AC unit and coach roof
  • Dometic Master
  • 6,674 Answers
Not very often that occurs but possible. If it has been running well for quite a while and not leaking, just double check that all 4 bolts are snug, but don't tighten too much and compress the gasket too much. I suspect that drip tray may be cracked, or drain holes plugged, and that is what is dripping inside. If it doesn't leak when unit is shut off, and it's raining, then I would pull the cover off, and check for blockage in all the drain holes. In order to properly clean 2 drains at evaporator coils (rear of AC), you will likely have to remove screws holding cover over it, and carefully lift it up and out of the way. Hard to see, but there is usually 2 drain holes in there, one on each side, and the tubes get plugged as well. Make sure power/hydro is off to unit for safety. If it does leak when raining, and unit off, then I'd say gasket needs replacing.
Posted on Apr 28, 2010
Testimonial: "Thanks for the answer. The 14x14 gasket is cheap and the damage from a leaky roof could be large. New gasket on the way. Honey Motor Home owner "
Roof leaking on 2003 breckenridge camper
Most roof ac units sit on a seal that fits around the opening outside, and on the inside there should be 4 long retaining bolts that that have or go thru some brackets, that squeeze the unit down. Kinda "sandwich's" the roof, if you will. I've simply tightened these 4 bolts carefully, and stopped the leak. Or the seal is damaged. And it also may be the drain. The opening will be under the plastic shroud. With the shroud removed you should be able to see a small opening near where its wet on the roof. I normally spray quickly with water at the opening. It normally clears easy. Condensate drain or weather seal.
Jun 27, 2015 | Heating & Cooling
2003 STS cadillac leaking water on both driver and passenger floor boards
It could be the sun roof. It also could be clogged drains from the sun roof. It may also be door seals Leaking. It could also be leaking around the bottom of the windshield. A good way to narrow it down is to get inside the car and have someone spray the outside of the car with a water hose. while you look for water leaking inside of the car. If it does it while the ac is on may be a clogged ac drain. however it usually just leaks on passenger side when it is that. well good luck.
Jan 13, 2015 | 2003 Cadillac Sts
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
My roof top unit is letting the condensation run into the coach.
Either you need to replace the square gasket between the ac and the roof or you need to seal/replace your roof..
Aug 03, 2010 | Coleman Mach III Air Conditioner
Help. Just had seal replaced now water flows in rather than leak. Of course the place that did the repair is hundreds of miles away. How do I tighten seal?
It could be that the installer did not tighten the mounting bolts sufficiently to make a seal. Taking the cover off the unit inside the coach, you should be able to see four mounting bolts that are inserted through springs between their heads and the ac unit.
Those mounting bolts are what pulls the AC unit snug against the gasket. The instructions say not to overtighten them when you first install them because you need to leave space to tighten them later as the gasket ages and loses its "spring". The gasket also, over time, compresses under the weight of the AC sitting on the roof "bouncing" as you drive down the road, losing the seal.
So that you have room to tighten them later, the springs on those mounting bolts should not be compressed all the way. However the bolts also need to be snug enough initially to make the seal and not just barely threaded in. You should not compress the gasket more than 50% on initial install, but it should be compressed a bit.
Try tightening them a bit with a socket wrench (tighten all 4 to an equal depth), then spray the roof area around the AC with a garden hose to see if you still have the leak.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
I suspect water is seeping in under my AC unit...
The roof A/C unit has a foam rubber seal/one piece gasket that fits around the part you see inside the coach but must be put in pklace before the unit is inserted in the roof opening. Replacing is relatively easy but you will need to remove the interior trim Disconnect the wiring from the coach to the unit and remove the four bolts holding the unit in place. Then lift out the A/C.to replace the seal. They do leak because of age and compression by units weight. Good Luck
Jan 28, 2010 | Dometic Rooftop RV Air Conditioner
Leaks where it sets on roof how does it bolt to the roof
There is a bolt on each corner that tighten from the inside. You will see them when you remove the inside cover. There should be foam weather stripping around the opening that the unit sits on and then it's tightened up.
Oct 13, 2009 | Coleman Mach 15 Air Conditioner
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Apr 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
171 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
