Question about Kicker ZX10001 Car Audio Amplifier
My protection light keeps turning on.
I have a zx 200.2 kicker amp, and when the volume goes pass a certain point, the amps fades out. its powering four pioneer 6x8's, my head unit is a pioneer 42000 dvd double din. every thing is wired right, and its all only about two months old. it worked fine when i installed it and now its doing this. help me with this problem.
    Problem Solver:
  • 8 Answers
I'm almost positive that your amp is overheating. i would either buy another one or bring it in to the geek squad. but i'm 99.9% sure it's overheating
Posted on May 18, 2010
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
I have a kicker amp and my power light will come on once the music starts but not even a full sec later it fades into protect mode den bak green den red it jus keeps rempeating itself kan u help me
Maybe theres a loose connection in the power ic. causing the vivration of the casing when you on the volume control. you need a qualified technician to fix your problem.
Jul 02, 2010 | Kicker ZX10001 Car Audio Amplifier
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker zr360 in protection
unplug rca,disconnect spker turn on amp if light goes away start connecting with one rca and one spk wire and you will find the problem should go away '''''''make spk polarity is wright
Apr 07, 2009 | Kicker ZR360 Car Audio Amplifier
My amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
Mar 20, 2009 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
KICKER KX350.4 sound fading in and out
Does the amp continue to go into protection if you disconnect the speaker wires from the speaker terminals?
Apr 14, 2008 | Kicker 04KX350.4 Car Audio Amplifier
Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
225 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
