Question about Maytag HYE3657A Electric Dryer
Maytag-dryer\model number -- Ldg7304aae
Maytag-dryer model number -- Ldg7304aae
Tumbles but does not heat
  • frank thomas wilson
    frank thomas wilson May 11, 2010
    Check the entire venting duct work. If there is the slightest clog in it the moister sensor cuts off the heat entirely. The moister sensor works in two ways. When the clothes are dry the dryer shuts off when set to the auto mode if equipt. Also if the venting system gets clogged up it shuts the heating mode down. It is a fire hazard in the past and has been used for years to prevent house fires caused by dryers
  • 45 Answers
This is the heating element. they are easy to replace by removing the back cover. UNPLUG it from the power source first!! The part is cheap to.
Posted on Apr 28, 2010
My maytag gas dryer LDG7304AAE timer quit working runs forever no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Dryers
No heat for my gas dryer. Maytag LDG7304aae
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Maytag Dryers
Ldg7304AAE maytag dryer fuse
pn-306604 there is the part number and it retails for 17.25
Aug 18, 2010 | Maytag HYE3657A Electric Dryer
Dryer turns on, tumbles, and blows air, but not hot air
take off the bottom toe kick
look to the back left of the cabinet
you should see the heat element, inspect all the connctions, this model ahs a habit of burning connections
if all is ok it probably your heating element ive included the sears part number for you
37001134
its ver easy to repair this
the heater runs less than 30 dollars
Oct 08, 2009 | Maytag SDE3606A Electric Dryer
I have a maytag model 747g dryer. I dryer tumbles
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
Jul 17, 2009 | Dryers
My Maytag Gas Dryer model LDG7304AAE runs but won't heat. I have no idea what I'm doing but can follow directions well if anyone can help.
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please check all the above components.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 17, 2009 | Dryers
Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Dec 06, 2008 | Dryers
Maytag Gas Dryer Model # LDG7304AAE can't find access into dyer
HI pat its easy to gain access . theres 2 screws at the bottom of the frontpanel. remove these screws pull front towards you . now you have access. thanks the appliance doc. please rate my answer.thanks
Oct 08, 2008 | Dryers
Maytag Gas Dryer LDG7304AAE won't heat
Probably a high limit fuse. Check on the burner shroud for a 2 wire thermos. They should have little resistance. If so replace. If they are open, check for a restricted vent. Remove front panel and clean out area below filter.
Nov 12, 2007 | Dryers
Maytag HYE3657A Electric Dryer Logo
474 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
