Question about HP PhotoSmart 7960 InkJet Printer
HP 7960 says printer calibration load plain paper, I tried all different paper did a hard reset and nothing changes
leroyal
  • 2120 Answers
SOURCE: HOW DO I CLEAR A PAPER JAM, IN MY HP PHOTOSMART 7960 PRINTER
Look in the rear of the machine for a large knob that releases a door.
Posted on Dec 28, 2008
  • 105 Answers
SOURCE: message on printer printer calibration load plain
Well this is simple but iratating
There are paper feed from begining to end Im gonna say this is a manuel to static printer this is simple in the sense that you do not need to really do anything accept keep it clean. When you drop the paper in the printer you need too let feed dont stick it in there let it sit in the carrier and the printer should grab it if not You may have gotten a lemmon Take it back and tell them HEY IM NO ******!!!!!!!! You know that
Posted on Oct 18, 2009
  • 80 Answers
SOURCE: WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Posted on Feb 11, 2010
puertobori
  • 7733 Answers
SOURCE: After installing new ink cartridges, the 'printer
Try Using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
Posted on Nov 02, 2010
undernet01
  • 492 Answers
SOURCE: Hi, I have an hp
It seems like the printer still thinks that the cartridge latch is broken. Did you just replace the latch or did you replace the entire mechanism? Printers aren't as smart as us so even though we perceive something to be fixed, the printer might still think the problem exists. If you just replaced the latch, then try replacing the entire part that's attached to the carriage.
After you replaced the latch, did you unplug the printer from the outlet for at least 60 seconds? If you only unplugged it for a couple of seconds, the printer would have still held somewhat of a charge. However, if you unplug it for a full minute, then it should wipe the memory on the printer.
Another thing to check is if you are doing the maintenance tasks from your desktop or if you are doing it from the printer itself. If you're doing it from the Desktop only, then your computer might not be feeding the necessary information to the printer to tell it that the problem is resolved. If this is the case, uninstall and reinstall the drivers from HP's website.
Hope some of this information is helpful. :)
Posted on Feb 10, 2011
Why after every print does job printer wants to print calibration page
Are you using original Ink or a replacement / refill , my HP is very picky about resetting for a new cartridge if it isn't a new cartridge
Apr 18, 2016 | HP PhotoSmart 7960 InkJet Printer
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
HP designet 4000 ps...changed out all of tghe printheads and getting banding, on plain paper and worse on matte film...ran the alignment and color calibration...any advice
hi
This is a problem with the paper axis motor and needs replacement.
Try to calibrate the plotter with a original HP photo paper and this is solved in many cases.
Jul 14, 2011 | Office Equipment & Supplies
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Message on printer printer calibration load plain
Oct 18, 2009 | HP PhotoSmart 7960 InkJet Printer
Not printing black
To align the printer from the control panel
1. Load letter, A4, or legal unused plain white paper into the input tray.
2. Press Setup.
The Setup menu appears.
3. Press to highlight Tools, and press OK.
The Tools menu appears.
4. Press to highlight Align Printer, and press OK.
5. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
Recycle or discard the page.
A success or failure message appears.
Note If you have colored paper loaded in the input tray when you align the printer, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or ink
cartridge.
6. Press OK to continue.
7. Recycle or discard the page.
Oct 13, 2009 | HP Photosmart C7280 Laser Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Printer erroneously reports a paper jam
Perform a hard reset of printer and see if that clears up the situation. Also uninstall and reinstall drivers.
Sep 04, 2017 | Office Equipment & Supplies
Hp photosmart c7280 won't work states calibration off
Solution
If the color or photo paper is loaded in the input tray when the printer aligns, the calibration might fail.
Follow these steps to resolve the issue.
Load unused plain white letter or A4 paper into the input tray.
Press the OK button on the control panel.
Cause
An incorrect type of paper is loaded in the input tray
May 30, 2008 | HP Office Equipment & Supplies
HP PhotoSmart 7960 InkJet Printer Logo
264 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
