Question about Arris High Speed DSL Modem
WEP key I want to find the WEP key on my modem where is it located? Thanks
    President:
  • 2,049 Answers
Your DSL modem does NOT have wireless capabiltiy and therefore has no WEP. Do you have a wireless router attached to the MSTATEA? If so, it has WEP security encryption. Please let us know make and modl of the wireless apparatus you are using.
Posted on Apr 29, 2010
Testimonial: "Thank you!!!"
I am trying to get the wep key from a wireless modem called westwell0260.. WPA # 1p45Y11Ypwk
WEP key is usually located at the bottom of the modem on a sticker.
Aug 27, 2011 | Computers & Internet
Hello I would like for my wii console to connect wirelessly onlne to enable my netflix to be connected andveiwed. I am in need of the correct wep/wpa access key. What is the best way for me to locate this...
If there is one already set up by default, it might be located on a sticker below your router/modem/box. And you will definitely find it in the configuration of the router/modem/box, via it's web interface
To access to the configuration page of your router/modem/box, type it's address in your favorite web browser. If it asks for a username and a password, type either "admin" "admin", "admin" "password" "admin" then blank, or both blank. If none of these are accepted, refer to the manual to get the proper login.
Then, in the wireless settings section, there might be a default wep/wpa key. You can change it, or create one if it's not present. I would recommend creating a WPA PSK password
Once all this is done, you can then go back to the Wii and start the process for the wireless connection wizard. you then enter the key you have retrieved/created on the router/modem/box and you are done.
Enjoy !
Apr 26, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do i watch i-player through my wii? got wireless connection,but got error code 51330 hope you can help,thanks!
The error code 51330 on Wii usually indicates that there is a problem relating to wireless security. You can try the following steps below as it should solve the problem:
If you are using WEP or WPA security on your router try this:
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
But if your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router.
1. go to our Wireless Router look up page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Lastly, Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
I hope the above solves your problem.
Good luck.
Oct 23, 2010 | Nintendo Video Game Consoles & Games
It wont let me connect to wii internet
here try the trouble shooting guide. Please try the
following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers
or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers
or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1
slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access
control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the
under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration
settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings
asked for by the Wii console during the Manual Setup process and enter them.
router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Aug 09, 2010 | Arris SURFboard SB4200 Modem
EROR CODE 52031 ON NINTENDO WII
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
Jun 10, 2010 | Video Game Consoles & Games
I need a wep code for an Actiontec GT704-WG. Trying to setup internet connection for wii and the code that is on on the modem does not work .
here is a setup guide to help you get the wep key. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
May 15, 2010 | Actiontec GT704WG Wireless Router...
Can't find security key
the wep/security key on 2 wire modems is located below the serial number label on the side of the modem.
Sep 25, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless adapter fails to negotiate with a secure modem
Ok, It looks like you have a DSL connection for your internet service. The problem you are having is that you are missing the WEP key inorder to connect to the modem with a secure link. The Modem has to be set to use WEP security and then there are a number of security keys that can added for security. Your modem is not configured for WEP, otherwise you would not be able to connect to it with no security.
You will have to read the information and access the modems setup features to enter the keys. You may have to go to the manufacturers web site and download the manual from it. If Verizon does not give you access to the modem for adjustment then you may need to have them setup the wep and email you the keys so you may copy and paste them into your connection configuration. Depending on the security level of the modem the longer the key the more secure. Some modems use a transmit key and a receive key in order to make the connection more secure. I would also check the modem and see if it has any options for WPA security, which are much better than the WEP. On any computer that connects to the network you have to create the connection with the WEP key or keys. If the modem uses these different keys then you have to match them. Say the modem WEP key is X to transmit and Y to receive, then the computers WEP would be set to Y to transmit and X to receive. The keys are also case sensitive numbers and letters, and the longer the better for network security. The manual will tell you the allowable maximum length you can use for the key. You can use the same key for transmit and receive if you wish to make it easier on you, but it all boils down to the type of security you programmed into the modem.
Read the owners manual for the modem and then you will have an idea what and how to get the two wireless connections to talk securely to each other. Currently your system is wide open and anyone can log on to your system without security, even the next door neighbor. Good Luck, RAC
Apr 19, 2009 | Toshiba Satellite M45-S359 Notebook
What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
The WEP key is located on the silver label on the bottom of each unit under the Serial Number and is clearly marked on my unit.
Mar 21, 2009 | Computers & Internet
Adding another computer to network
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Jul 19, 2008 | 2wire (1000-000057-000) Modem
Arris High Speed DSL Modem  Logo
458 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
