Lost power, when it come back on green light on front flashing, tried all that troubleshooting said and it will not flashing. Mitsubishi 6275
  • 12,061 Answers
Http://www.techlore.com/downloads/file/39528/WS-A48_VS-A50_WS-A55_WS-A65.pdf
OK use this Service Manual above, to troubleshoot and repair your set. This is what the engineers use to find and repair all faults.
Posted on Apr 28, 2010
Yesterday we had a power outage. When the power came back on, my TV would not work. The green light on the front just keeps flashing quickly. I tried unplugging it, and I unhooked all devices from it as...
Thats caused by weak capacitors on the DM board. They drain when the power is lost then they cant recharge after power is restired. You can get the dm repair kit for your model at www.tvrepairworld.com it contains the repair instructions and the upgraded caps plus other service info on the cd
Jun 07, 2011 | Mitsubishi Televison & Video
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light won't stop flashing. Unable to turn off/on or reset.
Aug 21, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Flashing green light
This is a very serious problem. The green blinking LED means the TV is reading its software but it can't complete the task. The cause is the premature failure of dozens of capacitors on several circuit boards in the TV. To properly fix this, the chassis needs to sent to Mitsubishi for rebuilding. You'll need to contact a Mitsubishi authorized service center to do this. This is expensive and takes quite a bit of time.
michtech
Feb 19, 2009 | Televison & Video
TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi
Please verify Model # and mo/yr built on back of TV........T.
Nov 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Televison & Video Logo
213 people viewed this question
Top Televison & Video Experts
Electro Med Services...
