Question about Samsung LN-S4051D 40 in. LCD Television
Hi. I have a bright streak going down the front
Hi. I have a bright streak going down the front of my flat screen. Have shut it off and on and it is still there.
  • Samsung Master
  • 12,061 Answers
Ok, this is a classic LCD fault, unfortunately, your Screen "Element" has gone faulty. There is NO repair, replacement of said "Element" IE: The LCD Screen. This is an expensive repair. In my professional opinion, you need to take it to a Samsung, authorised, service venter, then ask for a "Quote" for repair, that way you can be appraised of costings and you can determine as to repair or replace.
Posted on Apr 28, 2010
Kodak M863 charge ok checked battery is charged and tried new battery. Within one day battery is flat.
Go into settings, close wi fi and blue tooth. change screen brightness , change time on screen shut down.
Oct 29, 2014 | Kodak EasyShare M863 Digital Camera
Tcl tv screen
hi go into the menu on your tv scroll to picture setting turn the brightness down also look for bl which means back light set it to about 10 hope it helps
regards
shaun
Jan 25, 2014 | Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    I have only had this tv for 2 years. Sony Bravia 32". Black streak going through top of screen & light streaks going vertically down the screen. Also happening on the same day this happened. ...
    sound like inverter is going bad.
    if you got streaks might have gotten hit by something.
    also power supply might be going bad. if you have not clean it of dust, overheating could be the culprit.
    good luck
    Oct 29, 2010 | Sony Televison & Video
    Dark shadow-like vertical streaks thru LCD screen (Sharp)
    Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
    Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
    LCD screen glows super bright then shuts down with red pwr lite
    The ps voltages need to checked with inverter plugged in otherwise you can't verify a p/s failure. most likely you will need a new inverter/ps. Julio milleniumtvsvc@gmail.com
    Jul 22, 2009 | Televison & Video
    Akai lct 2701td comes on then shuts down
    Hi
    You have power supply problem. Please go to ebay and buy cheaper price:
    AKAI LCT2701AD POWER SUUPLY MLT166A
    Thanks
    GEORGE
    Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
    Streaking inside of screen
    Philips screens tend to be very tough to remove as if you are not careful on removal of the screen frame bolts then the whole screen will come falling off.
    Mar 19, 2007 | Philips 44PL9523 44 in. Rear Projection...
    Monitor blackening out and sudenly shuting down...
    Hello! Sorry to hear of the Tennis Ball Masacre. I believe your problem to be twofold in nature. First the glass in side of the LCD screen is very fragile and the tennis ball most likely ruptured it. the streaks are most likle the liquid crystal solution leaking out. the dark streaks represent the absence of the fluid. Secondly, the monitor shut down appears to be from the back light / inverter circuitry. Sounds like it may be time for a new display. $40 to $60 for the inverter board and $80 or more for a new display screen, you may as well go the couple of extra dollars and get a new monitor. Hope this puts it in perspective for you. Sorry it is so bleak!
    Aug 11, 2006 | Dell E173FP 17" LCD Monitor
    Samsung LN-S4051D 40 in. LCD Television Logo
    205 people viewed this question
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
