Question about Zoom 5241 Modem
Whats the ip adress or gateway and default passowrd to the zoom 5241 cable modem
    Novelist:
  • 142 Answers
  1. Go to Start - Programs - Accessories - Command Prompt
  2. Click Start - Run (or Windows Key+R), type "cmd", then press enter. Note: you don't need to include the speech marks.
  3. Similar to the above, on Windows Vista or 7, open the start menu, type cmd, then press enter.
On the black screen type
IPCONFIG and then hit enter
there you can find the ip address
For password you need to contact router vendor or ISP
Posted on Apr 28, 2010
I cant open my WIRELESS ROUTER |WL-520G - RT (WL520GC) on my browser; if i open the default gateway the isp modem settings pops out not my asus router seting... pls hep
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
Aug 06, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
What is ip address of 5241 modem?
The default IP address is 192.168.100.1 but this modem is not designed to be access by the consumer, only your internet service provider. See below for more details:
http://www.speedguide.net/broadband-view.php?hw=142
May 04, 2011 | Zoom 5241 Modem
For diagnostic purpases I need to obtain the IP adrress of my Zoom 5241 cable modem. My Asus router IP is 192.168.1.1. I recently purchased this modem to save rental fees on the modem that Comcast...
Just use command prompt, at the 1st moment when you connect your router, no matter LAN, USB or wireless/blue tooth or even HDSPA modems connection it will assign itself a port on your machine, to check what ip adress your Zoom 5241 cable modem got, go to Start, then run then type CMD for command prompt screen and in the console, type ipconfig/all on list you will find your router, simply find "default gateway" part and use that local adress xxx.xxx.xyz.xyz.
Please rate my solution :)
Apr 13, 2011 | Computers & Internet
Hi, Our modem seems to work fine when plugged directly into a computer (we get internet okay), but if we plug it into anything else it won't get internet. We've tried two different routers and a Wii and...
Without further information, my best guess is that your modem has the same IP address as the common IP address for routers and probably the Wii. Most wireless routers have the address 192.168.1.1
Try connecting a computer using a hard line (a network cable) to your router and type in this address, it will most likely come up. If it does change it's static address to 192.168.1.12 (actually any number behind the last period above 1 and under 255.). Also set its gateway to 192.168.1.1 to access your modem. (Also in the router settings which are found by typing the address mentioned above, 192.168.1.1) Be sure to note this new address if you want to access your router without resetting it and using a hard line again. The Wii should automatically pick up signal from the wireless router. If for some reason you want to switch between the Wii and a Router by way of hardline, you must contact the maker of your cable modem (or cable company) and find out what the IP address is in order to access it's settings (the same way; by typing it's IP address into a browsers address bar.) By setting the modem to have a different IP there would be no conflict with the other products which (rightly) have the IP address of 192.168.1.1 as a default.
Hope this helps!
Dec 08, 2010 | Zoom 5241 Modem
What is it?
default is http://192.168.1.1, but you can check by ip gateway (modem adress), on your computer.
check your local network connection:
if your modem is directly connect your computer, by usb or LAN the gateway adress is the same, you can test if go to the webrowser and type the same adress as before.
Dec 26, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
D-Link 2100 AP is working in Wireless Client mode. It is connected to home network with cat5 cable. The remote ADSL modem is 192.168.1.1 and DHCP on. The first computer in the network obtains IP and...
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Nov 24, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Cannot access belkin 54g wireless modem settings
Try geting a routher that featres wirless and eathernet so you do not have to have two boxes. You will have to know its ip adress enter it internet explore and then you will be able to protect it through there.
Jan 03, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
The routers I P address
set your ip setting to "Obtain an IP address automatically", then plug your ethernet cable to your system, once connected, open a command prompt then type 'ipconfig' (w/o ""). your IP add, subnet mask & default gateway will display. take note, the default gateway is the ip address of your router.
Dec 04, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Configuring ppoe connection with zoom modem
Your external (WAN) IP should be set to DHCP for most ISP's. Your internal IP will be the default gateway for everything in your LAN to get sent to. If you can log into the zoom with your browser, try that IP address for your gateway. If not can you let me know some more details on your zoom model.
Aug 02, 2007 | Zoom (56600000) DSL Modem
Zoom 5241 Modem Logo
573 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
