Question about Systemax AOL Optimized PC (100607) PC Desktop
How do I find mixer devices and audio input devices
  • 157 Answers
Go to Control Panel. Then Sounds and Devices. Then Hardware.
Posted on Apr 28, 2010
Please! show me how to connect an electric acoustic guitar to the mixer
You can't. A mixer won't take the input from a guitar. You would need to connect the guitar to an amplifier and then connect the output from the amp to the mixer.
A mixer is what it is, a device to mix lots of incoming audio signals and mixing the volumes to a number of speakers.
The unit does contain pre-amps, but not to run a device.
http://www.prosoundservice.com/m9/MACKIE-CFX12-mkII--mackie-cfx12-mkii-12-channel-compact-sr-mixer-with-effects.html
Apr 17, 2016 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
How to know if fuse is blown in my optimus ssm-50 mixer
The only fuse in that device is on the power input. If the fuse is blown, the mixer wouldn't power up at all - no lights, no signal, no nothing. It would be the same as if it's switched off.
Aug 26, 2013 | Audio Players & Recorders
I just bought this mixer and can't seem my existing Cubase recording software to recognize it for recording. Do I have to run the mixer thru my existing interface or can the Cubase setups be modif
The mixer allows you to use the USB connection for recording without having to use an additional interface. Make sure that you have all of the proper drivers installed for the mixer. Regardless of whether you're using Mac or PC, you should be able to see the device in your list of available Audio Devices. If you do, you need to adjust the proper settings in the Cubase Audio preferences to make use of those inputs.
May 29, 2013 | Mackie PROFX12 Professional 12-Channel...
Firewire inputs do not work
Check in the computer "Device manager" if a PC with windows, and see if there are any devices with an yellow "X" through them- the port may have an interrupt conflict.
Then check audio properties of the system to make sure the devices are selected and enabled, and their volume level is up- even if you are operating through the Mackie software console.
If a Mac- check the Chooser to make sure that input device has been selected.
Mar 30, 2012 | Mackie Onyx 1620i Recording Mixer
My new behringer vmx 200 dj mixer dosnt play sound from ch1 ...ch2 works fine ive tried everything but ch1 dont work
be sure when you select the chennel 1 input as your audio source you have an audio device plug inn at the channel 1 audio input..
Sep 11, 2011 | Audio Players & Recorders
In have an new HP and instulled Audio Audition 1.5 while in multitrack view and am trying to record, I get a "Device ID out of range message" I've tried mostly everything.
Wow, it sounds like you didn't set up a device in the mixer for stereo input, or Adobe deadpanned that you wanted to record mic in and didn't ask to fix that going into multitrack. I've seen that often enough teleconferencing from WinXP swapping audio devices in and out, but by Windows 7 and 2011...this is a surprise. Just activate the appropriate line in in the input mixer in Windows (or more likely, your multitrack input mixer's controls.)
Surely this isn't it, and Adobe wants you to walk through the input level test modules first?
Mar 13, 2011 | Adobe Audition 3 for PC (22011292)
Output form computer to board using USB works but the signal for input doesn't work
In the control panel, "sounds and audio devices" under the "voice tab" make sure the INPUT is set to the Xenyx device.
Dec 01, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
The problem is me not the gear (px2000) I'm not sure how to use it I've got various pieces of kit:- Mixers - Drum machines - sound modules - reverb units - three sets of speakers (2 active & 1 passive)...
Hi well to wire it all up,isn't too hard, if ya can follow the diagram above, it's a rough, very, diagram of how you could go about hooking it all up.
The AMP is sort of the central thing, the speaker plug into the OUTPUT side of things. Then on the INPUT we use our MIXER, to Join all our "Other" INPUT devices, Drums, sound modules and reverb units, the reverbs always go between the Input device and the Mixer.
Now if using a patch bay all the inputs go to that then to the Mixer and on to the Amp, out to the speakers.
You could use the PC to control them all, and use the USB audio interface to deliver audio in.
Aug 12, 2010 | Computers & Internet
How to connect mixer an amp to laptop?
How is everything hooked up?
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
Mar 20, 2009 | HP Pavilion dv9000z Notebook
Systemax AOL Optimized PC (100607) PC Desktop Logo
26 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Mike
Victorman
Victorman
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
