Question about Toshiba Satellite A105 Notebook
NEED DIRECTIONS ON HOW TO INSTALL DC INPUT FOR TOSHIBA
My Dc input is broken so i ordered a new one DC input 16v but i do not know how to replace it. can someone PLEASE give me step by step directions? I have friends that are really good with computers that promised they would help fix it but they keep bojangling... i have been waiting for my computer to be fixed for months and i am too poor to go get it fixed by a computer place... DIRECTIONS PLEASE????
  • Big E
    Big E May 11, 2010
    can you state brand and model and clarify if you mean the jack where the charger connects to I will give you a link to the schematics I done that in several occasions and if that's what it is you have to be good with soldering guns it has to be taken apart
    let me know
  • frankdanfelt May 11, 2010
    I am confused by what you mean the DC input is broken. Are you referring to the AC adapter? Or do you mean where it plugs into the rear of the unit?
  • 95 Answers
This is not something you can do yourself. It requires soldering. You first have to remove the old jack then solder the new one to the board.You can,t over heat the board and alot of other stuff. We repair jacks for 110.00$.Look us up on facebook...rippy computers or call 704 820-6433.we would be glad to help you if we can.We do alot of mail order repairs.
Posted on Apr 28, 2010
I picked up this monitor at a yard sale it says dc input?? is this the power supply? how do i hook up a ac cord?
If it says DC input and there are no other socket which has three prongs(this is for the AC input), all you need is an adapter, which you will plug to a wall socket and the other end would be plugged to the flat panel, it works like a transformer, just like any power supply, like for laptops, just try to find the correct voltage, 12v,16v or whatever is needed by the panel. Often you can find the voltage require on the panel itself, reading as POWER INPUT, xx volts or Power requirement.
Thank you for using Fixya.com
Oct 27, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
The input on the laptop where i stick the charger inn isn't working, what do i do?
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop
Oct 09, 2010 | HP 6530b Notebook
I have a broken DC input jack on a Satellite Pro A210-16V. I am simply trying to source the spare part to fix it myself! Thanks!!!
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3211
^Copy-paste in browser^
Kinda pricey, but it's the whole harness. No soldering required.
**Open up your machine and visually compare them! It SHOULD be right, but sometimes they're different even though they are for the same model.
Hope this helps!
Feb 23, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Our Laptop just keeps going off. Replaced the AC Adaptor, and still having the came problem.
Need more info, but if it powers and shows it is charging, then it is probably a heat issue. I would try taking a can of compressed air to the fans and air slots. try to get any dust out.
Otherwise, if it is not charging properly it may be the dc input, meaning either a dc input cable (about 20$) or a new mother board (a few hundred);
//halfs
Feb 14, 2010 | Toshiba Computers & Internet
The AC adapter input in my Toshiba A505 S6960 has broken after 75 days of use. Have you heard of this type of problem happening often
Hello there:
Yes this is a common problem it doesent happen a lot but yes it does happen What you need to do to repair it is tounplug thecomputer and remove the battery then open the case on the laptop and unsolder the old dc jack that is on the mother board and get a new dc input jack solder it back in place the piece costs about 15 dollars
Not real hard to do just takes time and patience ok?
I hope that this is very helpful for you.
Best regards Michael
Nov 20, 2009 | Toshiba Satellite A85-S107 Notebook
I have a Toshiba Satellite Laptop Model A15-S129 - The unit shut down and never would restart. I Checked the AC Adapter and it has no DC output voltage. I do have a 15VDC 2A Adapter connected to it now,...
hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try input..do not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
May 17, 2009 | Toshiba Satellite A135-S4467 Notebook
DC input jack broken
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
I own a four track recorded, but to get it work i have to manually apply pressure to the power input in order for it to turn on. is it possible for me to fix this problem so that i dont have to fuss around...
Hello!
You have a dc jack for power input or an ac line?? I bet dc jack...Take the unit apart and solder the broken connections at the dc jack. I have done it over 1000 times...literally. Good Luck!
barneyluc
Oct 11, 2008 | Audio Players & Recorders
Steps to replace DC power jack L15-S104
its not so easy to replace you dc jack please don't try your self....
Apr 25, 2008 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite A105 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
