Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Picture is distorted. Red band from top. Is this a repair I can do myself?
  • Samsung Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Posted on May 15, 2010
A band of color for a picture on my 50H72 toshiba projection tv suddenly becomes either half a picture with a thick band of color on top or just becomes a band of color with no seeable picture. We have...
The most likely cause of a problem such as described is failure of the "Hyper Module"; this is one of the "stand-up" PCB's on the main signal PCB (which is the one on the right when viewed from back of set). These modules have a history of failure of the multiple electrolytic "surface-mount" capacitors; successful repair of hyper modules usually entails replacing all caps on the board, and often some solder repair as well...the degree of soldering expertise required to adequately service such products will usually preclude all but professional repair
Mar 04, 2010 | Toshiba 46HM95 46" HDTV
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Red green wavy color on top of picture with distorted faces and bottom of picture seems o.k.
Ur convergence is dead.The Convergence board must repair or replaced.Samsung/Akai use the same convergence board.Try website Tv repair world.com.Buy the whole board replaced it the best.
Jan 15, 2010 | Akai PT5598HD 55" Rear Projection...
Words are distorted and screen has a band on top and bottom
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2010 | RCA HD65W140 65" Rear Projection...
Same problem as above, picture bowed top and bottom, convergence
Projection sets have two very common problems outlined below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
bb0cf99.pngSOLUTION
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Distorted picture on screen
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | RCA P60920BL 60" Rear Projection...
Green and purple band of color
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
GE 46GW945
Your problem is a bad main filter, a regulator IC ,and or a combination of a convergence problem along with a vertical IC going bad. This set is not something you should mess with unless your a trained tech. Please seek a pro to assist you with this repair. good Luck
Jul 28, 2006 | GE 46GW945 46" Rear Projection Television
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
454 people viewed this question
Jerry Greenberg
Jerry Greenberg
