Question about Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator
My frigidaire side by side won't give water or ice. unit approx 13yrs old
  • kellyjoey Apr 29, 2010
    The water supply is fine. The water just won't get thruogh to the water dispenser
  • Rick Ead
    Rick Ead May 11, 2010
    have you checked the valve in the back of the machine to see if your getting water to the machine
  • 1,998 Answers
Pull off the panel in the front of the machine be careful this is very fragile check to see if your getting power to the switch on the door also check that the switch is not broken there is also a control that is on the inside that you can test to see if your getting power to
Posted on Apr 29, 2010
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire side by side is not cooling. 3 monts old. Ice melted in Ice maker and Water running out icd dispencer on front freezer door.
If you unit is only 3 months old then it is still under warranty so call the store you bought it from and have them fix it.
Jul 04, 2011 | Frigidaire FSC23F7D Side by Side...
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Hooked up waterline to side by side frigiedaire,
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
Water dipenser broke
drip tray pulls foward (might take some serious finger strength but itll pull foward, revealling 2 phillips screws that will release the dispensor facade. before attempting i would unplug the harness atop the freezer door, you dont want to short circuit boards behind dispensor.
Oct 19, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Making ice very slow and small
Hello, have you tried replacing the water filter? You did not say how long you have had this unit? What is your water pressure? Should be a minimum of 30psi. Good Luck! Dr. Know
Oct 14, 2007 | Frigidaire GLHS66EE Side by Side...
Frigidaire FSC23F7DSB Stainless Steel Side by Side Refrigerator Logo
120 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
