I am the guy with the sony KV27S42 tv. I have a B+ overcurrent indication. My question is as follows: Supposedly the set shuts down after 7 vertical traces. The set stays up for 4 to 5 seconds before it shuts off the power relay. Does it turn off the flyback immediately so that I would not be able to voltages on its terminals or does the unit stay on for the 4 to 5 seconds that power is on? I can't get any voltages from the flyback.
  • 4 more comments
  • schmitt_alvi May 02, 2010
    Hi -- I disconnected the collector of Q502 which is the Horizontal Output from the foil. I left all other parts connected including the flyback transformer. The error light changed from a two blink to a four blink which indicates that +13 volt was not available. So that indicated to me that the flyback was working producing the +13 volts when the Q502 was connected. Maybe what is to sense the +B overcurrent is not working or pin 18 of IC301 which senses the B+ overcurrent is bad. What do you think? Thank you. Alvin....
    I get 135.7 volts (is that B+ or is it the 200 volt line?) I disconnected the 135 v connection from the flyback. I disconnected the collector of the Horz Output transistor going to the flyback. I still get 135V. Disconnecting the C of Horz Out with the flyback caused the +13v supply to not appear causing the 4 blinks . If the +13 is working could the flyback still be bad?
    Now, after resoldering the pin back in circuit I do not get 135 v at that flyback pin. Also I do not see the heater voltage when I turn on the TV. Should the heater V be on while the few seconds that the TV stays on? Thanks for all your help.
    I am going to replace the flyback transformer. I will leave a note when done. Yes you have talked to me before. The set is a SONY KV27S42 BA4D chassis.
    I removed and replaced the flyback. The set comes up now but makes scary noises of a high voltage nature. It stays up for about 15 seconds before shutting itself off - Shows a green raster with the set trying to develope a totally green screen without any raster. I hooked up a tv signal generator and placed the set at channel 3. I see a wide (2 inch) raster along with a set of closer lines which may be the signal generator output. It still shuts off, now after 15 seconds, and blinks the light twice indicating the B+ overcurrent still.
    SD provided all the help I needed. The only better thing would been if he was here fixing it himself. Great Guy!!!!
  • 5,138 Answers
2 things Check video IC on CRT board,disconnect the CRT board on neck of tube then turn TV on.Also near high voltage FBT 47uf 160v cap or 100uf 100v capaitor.
Posted on May 02, 2010
  • ladywinn
    ladywinn May 02, 2010
    I think you are going to find Bad Tube,heres what happens tube begins to short and in return set burns FBT, it isnt untill you replace FBT that you will discover defective Tube.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
FIRST: trouble shooting suggestions:
1. Locate the pin where the b+ enters the flyback and unsolder it.
2. Locate the pin where the collector of the Horz output connects to the flyback AND unsolder it also; check for full b+ on the foil going to the flyback from the power supply---it should be in excess of 130 vdc and use the correct ground when you do this.
If voltage returned at the source going to the flyback the problem is either the transformer or something near it. If voltage does not come up at the source going to the flyback with both pins completely loose of the board, the problem is back in the main power supply.
Let me know if you have questions and what you find as I am here to help you.
SD TECH
Posted on Apr 28, 2010
  • 2 more comments
  • SD Tech
    SD Tech May 02, 2010
    Please consider unsoldering the two pins from the flyback to see if you get the b+ at the collector. If it is not there many secondary voltages do not come up and function.
    The 130 B+ has to be present. A set that is not producing High Voltage from the flyback may mean the transformer is bad. Most shops have a ringer to test the transformer out of circuit. The error codes and shutdown points can be misleading and the problem is more often the flyback or sometimes a open horizontal driver transformer.
    You got the 130 B+ or not?
    SD TECH
  • SD Tech
    I do not have a schematic of this model but yours should show where the 13 volts comes from. The term B+ refers to voltages from the power supply--you have the most critical one.
    You are sure the driver transformer is not open? You have carefully checked the board for bad connections or a possible crack?
    All this seems familiar to me and I wonder if we have talked here before about this set?
    9 out of ten times these sets have problems where the 130 volt is down, it will read higher with the set not working. If you have the 130 B+ with everything soldered back, it may be the high voltage transformer with a bad single winding inside it.
    If the voltage disappears when you solder the output and flyback back into the circuit, 99% plus chance the flyback is bad.
    Does all this make sense to you?
    SD TECH
  • SD Tech
    NO, if voltage is gone with flyback and output back in circuit next real possible part is the bad high voltage transformer.
    Give me exact model number of set and I will see if I can find online at a site that shows parts breakdowns for most sets the part number.
    SD TECH
    PS: I will be going offline here in about fifteen minutes for the evening and return at noon tomorrow California time.
  • SD Tech
    Part number is :
    1-453-268-21
    It is pricey from Sony at about 83 dollars but you may find a generic replacement on the internet for much less--I have done this with several of their sets.
    Search the part number carefully with GOOGLE and see what you can find.
    SD TECH
    Remember if you are satisfied to leave a "very helpful" rating so I get credit for helping you.
    I am going now and will see any further comments you make tomorrow.
    You are on the right path.
    SD TECH
I have a sony kv27s42 tv. it shut itself off last night and the red light on front of the tv is blinking. is there anything i can do?
Hi there stuibel,
is there any ticking sound that's coming from the inside? if there is than could be the relay (posistor)
that's causing your tv to shut down. need to replace that.
thanks,
George.
May 29, 2011 | Sony Televison & Video
My Sony KV-32HS420 won't turn on -- blinks 7 times, pauses, blinks 7 times. I've seen the same problem described on this site, and the answer seems to be that 2 ICs on the DZ board need to be replaced. I'm...
The 7 blinks on this model indicates that the horizontal section of the TV has stopped working. Horizontal Deflection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
I have the serrvice manual if you need it. Let me know where to send it to.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sanyo TV Model DS25500. Replaced fuse, but now it has a line across the screen? Does the picture tube need to be replaced?
Your picture tube is fine for now, but it won't be if that line is allowed to burn into the screen. You have lost your vertical deflection. Since a fuse was involved, that indicates that an overcurrent condition existed. You may have a blown vertical deflection IC, or there could be just a shorted diode, which caused the overcurrent, and subsequently burned a resistor in series with the diode, also acting as a fuse. It could be all three.
Apr 05, 2010 | Sanyo Televison & Video
I have a Sony Triniton 27 inch Model number KV27S42. It shut off while we were watching it, then it shut off. We got it to go back on and it shut off again. The red light stays on. It sounds like it wants...
power switch is not the problem .Unit is shutting down to protect itself from an internal problem.Very possible it needs repair .Try to find an authorized Sony dealer in your area if possible
Aug 05, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KD34XBR960- NO PICTURE blinks 7 times. Thanks
Stopped
7 times 7:0 or 7:1 • No picture
Horizontal Defl ection Stopped
Occurs when either:
IF YOU WANT TO DOWN LOAD A FREE SERVICE MANUAL OR TECH MANUAL FOR YOUR T.V. HERE IS A SIGHT THATS TOTALY FREE
http://www.schematicsforfree.com/archive/dir/Sony/Video
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV27S42 problem
The 2 blinks is an indication of overcurrent. That translates into a short somwhere inside the set. since you can get sound but no picture, that suggests that the problem is in the high voltage section. The most common failure there is the Horizontal Output Transistor. This is a 3 legged part attached to a heatsink close to the flyback transformer (part with large red wire coming out the top). That part should be marked C5438 or something similar. Post the marking here and I'll give you the complete part number.
Dan
Aug 01, 2008 | Sony KV-27S42 27" TV
TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Jul 08, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV27S42 dead - 4 blinks
the +13 and -13 are generated by the flyback transformer as well as the 200 volts. the 135 is your B+ voltage and sould be there at start up. check the HOT and the Flyback. if there is no 135v check IC1751 on the C board sometimes if bad it loads down the 135v line. and can give a faulse vertical error.
Apr 02, 2008 | Sony KV-27V42 27" TV
TV will not stay on for longer than 5 minutes
This sounds like the shutdown circuit is shutting down the TV due to an over current condition. This overcurrent condition is caused by a component in the HV section drawing excessive current. the 5 blinks is a visual indication of the problem.
Sep 08, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
