Question about Whirlpool LER4634J Electric Dryer
It doesnt heat up the motor runs but it blows cool air it is also electric
  • 10,319 Answers
Disconnect the entire venting duct work and clean if necessary. If clogged full of lint in one area the sensor prevents the burner to produce any heat. If clear throughout the moister control sensor is at fault
Posted on Apr 28, 2010
    Problem Solver:
  • 5 Answers
If you have not fixed the problem.. Usually when a dryer does not heat it has to do with the heating element and also the thermal cut off kit which is attached to the heater box and at times the element itself depending on your model. ck for broken coils then take an OHM meter and test for continuity to see whats not giving off any power for process of elimination. check the power cord to see if its connected to the terminal block in the back and that they are not loose.
Posted on May 25, 2010
The heater kicks on but only blows cold air
Air Temperature Control Blend Door Failure No Heat or no AC (dependes on where door sticks)
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Jan 03, 2013 | Cars & Trucks
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Heater blows only cold air
Dec 27, 2012 | 1999 GMC Sierra
Heater doesn't get hot on 96 chevy truck. Blows good, just cold. Replaced thermostat, flushed radiator. Any ideas?
Dec 06, 2012 | Cars & Trucks
I mitsubishi RKX502A001C that I cant get to blow hot and is only blowing cold air?
Nov 05, 2012 | Cars & Trucks
I have a 5 ton goodmsn heat pump it only blows cold air the heat doesnt come on have a new heat strip in it but still blows cod air
Heat pumps require a reversing valve for heat operation on the outdoor section, a control signal to a "O" terminal or orange wire is required for heating and cooling depending on the thermostat and out door unit requirements. The thermostat also has to be heat pump type for the system to operate heat for electric system with heat strip, two stage electric heating.
Jan 31, 2011 | Goodman CKL60AR60 Air Conditioner
We replaced the blower motor and it doesnt blow very much heat
you have air trapped in the cooling system. Go to our website and follow the directions to purge the air, or go to a shop that has evac/fill equipment. Have them flush and fill cooling system with their equipment. It gets all the air out.
http://groups.yahoo.com/group/villagerquest/
Dec 25, 2010 | 2002 Mercury Villager
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Motor fan blowing
do you keep the fresh air button on ? if you do , you will feel heat or cool air come in with out the blower motor running
Dec 01, 2008 | 2004 Chrysler Pacifica
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Whirlpool LER4634J Electric Dryer Logo
495 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
