Question about Dewalt D51844 Framing Nailer
Air leek where nails come out - Dewalt D51844 Framing Nailer
    President:
  • Dewalt Master
  • 1,388 Answers
Air leaking out the nose indicates that the orings that seal the bulkhead /cylinder spacer (white plastic ring around the cylinder) are leaking. Order oring kit from dewalt and replace all the orings. I dont remember if the kit containes a trigger valve but it needs to be replaced also or at least have a spare ready when the orings in it fail. Dewalt used some vinyl-like orings that failed (vinyl orings were also used in the trigger valve ). Good luck.
Posted on Oct 18, 2011
I have propulse 2 inch Brad Nailer. Model 57265001. when i press switch just air blow out but no nail or nailing
1. Does it have any nails in it? A) add nails
2. Often when you get down to the last few nails it will quit working. A) add more nails, you may have to discard the remaining nail or three before adding more nails.
3. You may have reached the end of a group of nails and the last nail or 2 are jamed up in the end of the nailer. A) Need to open end of nailer and remove jamed nails. Don't forget to disconnect nailer from compressor first.
4. Other options are not enough air pressure, or the gun is damaged and needs repaired or replaced.
Good luck.
Aug 02, 2016 | Air Tools & Compressors
Air noise when using break peddle in a 2002 Hyundai accent
The fluid leaking out the rear seal of the master cylinder has likely swelled/damaged the rubber diaphragm in your brake booster, causing the hissing sound. Unfortunately, you will need to replace your booster.
Feb 04, 2013 | 2002 Hyundai Accent
Wont shoot nail every time pin wont return all the way up
Some reasons the driver/piston assembly won't retract fully:
- damage to the o-ring (LB1003) around the piston
- cylinder (BA0165) is scored badly
- driver (EA0167) is bent, twisted or warped
- o-ring (LB1023) around bottom of cylinder (in groves & covering small holes) is stretched out or out of place.
- Seal (BC0492) at bottom of cylinder & under bumper is damaged or gone
Aug 11, 2012 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Leeking water
when ac runs, thats water coming out is from the humidity pulled out of the air
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Air bypassing when the trigger is pulled, nail gun will not fire
You will need to get a repair kit for that model and brand nailer. It has a leek in the diaphragm or a bad O-ring.
Aug 28, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Vacuum air leek on my 88 camaro
vacuum leaks can cause all the problems your describing and needs to be repaired
Mar 26, 2009 | 1988 Chevrolet Camaro
Porter cable roofing gun
The problem that you describe could be caused by three things. First remove the cylinder and look for a black rubber band around the cylinder about med section. There is an indention with holes where it is supposed to be. The band should fit snuggly so that it does not slip off during use. Secondly, check that the piston oring/plastic ring holds the piston in the cylinder without just dropping under its own weight. Third, the upper bumper could have a crack or missing piece. Remove it and check. (vinyl part in headvalve) Parts are available at dewalt repair center or www.toolpartsdirect.com. enjoy
Dec 06, 2008 | Porter Cable Cable RN175AR Reconditioned...
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Dewalt D51844 Framing Nailer Logo
466 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
