Question about Refrigerators
The fan is working ,the freezer is warm and the fridge is not cold,there is a clicking sound about every 2-3 minutes...
  • teehee310 Apr 28, 2010
    Thank you for your help, I am going to try to get the starter kit. I will let you know how it is going.
  • 10,515 Answers
You need to replace the start device on the compressor, if you click on the link below it will take you to a service site that has the parts in stock for delivery, This goes inside the plastic box on the compressor. It is a 15 minute repair and will get you going.
You could get it ( Starting Device Kit ) from :-
http://www.repairclinic.com
Note - If the Compressor would be at Fault, then you do have 5 Years Warranty ( Most of the Brands )
Refer :-
http://www.applianceaid.com/refrigerator.html#clicking
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 28, 2010
  • taran_2005
    taran_2005 Apr 28, 2010
    Thanks for your response!!
    Let me know,once done.
    Hope i helped you.
    day!!
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Fridge side not cooling i have unplug for a minute and plugged back in starts fine and then i hear a click sounds like compressior is running but not getting cold
first off what is the brand name and model number?is the freezer cold?if so when you open the freezer door do you hear the fan blowing?all a fridge does is get cold in the freezer and the evap fan blows cold air from the freezer to the fridge side that's it,if you don't hear the fan when you open the freezer you have a bad evap fan motor,but send more info.
Apr 09, 2011 | Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Fridge is warm with no cold air.
Unless there are 2 thermostats, one for freezer and one for refrig, it's not the thermostat if the freezer is ok. Sounds like the small fan that blows the cold air from freezer into refrig is not operating.
Jul 23, 2010 | Refrigerators
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Clicking sound and warm temps
Sounds like the compressor is frozen and won;t turn. a slight chance that it starter relay is bad, you will need to get a repairman to check it out.
Jul 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Fridge and freezer not cold
It happenedn to my performa fridge just yesterday. It was bought in 2005. Now there is humming and clicking sound from the lower back side once in a while and the fridge is not cold. the compressor is hot/warm and it seems to be where the noise is coming from.
Jun 21, 2008 | Maytag Performa PAV2200
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
