Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Smoke coming from motor
I need a schematic on replacing the motor
  • 549 Answers
Http://www.globalsources.com/manufacturers/Vacuum-Cleaner-Motor.html
There is a ton of vacuum cleaner motors at this link.
Hope it helps.
Posted on Mar 25, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Mar 25, 2008
    Hoover does not have the motor you need.
  • Hjalmer Lamminen
    The motor will cost about 80 to 100 dollars.
    The vacuum may not be worth that much to fix.
    Also, check brushes, maybe they are short.
    Genius:
  • 3,422 Answers
You can download the user manual from HERE
Since the service manual is not available on the net you will have to contact the Hoover people for it.Here is the contact no.
1-800-944-9200
Here is 1 tip which i can give you:
From the bottom, remove the screws separating the top and the bottom. Then at the bottom, remove the round water seal, take out those screws, ( careful with the water seal, reglue it with contact cement when you put it back on). At the top of the motor, take out the screws around the motor and it should pull out.
Goodluck,
Please don't forget to rate the solution:
  • Hoover Master
  • 19,396 Answers
Here you can buy a spare motor. I will see if I find schematics
  • 3 more comments
  • Ginko
    Ginko Mar 25, 2008
    I did not find the service manual , but here is the exploded view for a general model from same series.
    I could npt find a free service manual , if I find one I will post it here.
    Let me know if you need further help.
    regards
  • Ginko
    Ginko Mar 25, 2008
    Note In the explosion above the motor is part nr.44 (scroll down the page). Replacing it should not be too difficult.
  • Ginko
    Ginko Mar 25, 2008
    Here are full schematics for model u6625, which is very similar to u 6616, at least motor assembly is the same. Motor assembly are parts from 42 to 47. Have a look.
  • Ginko
    Ginko Mar 25, 2008
    Please do not forget to accept the better solution.
    Many thanks
  • Ginko
    Ginko Mar 25, 2008
    Bingo, here are schematics for u6616 , as I told you they are not very different from model above
Need to replace vaccum motor
Before you can get a schematic for any vacuum, you're going to need the model number and make. Neither of which you have listed here.
Nov 09, 2013 | Vacuums
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Feb 16, 2009 | Kenmore Vacuums
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Vacuum plugged in but not on, smoke started coming from the motor
The motor winding burned out. Perhaps the motor was very hot when the vac was turned off after the last use and the insulation of the motor windings broke down when the air stopped moving thought the unit. Perhaps also the polarity of the receptacle it was plugged into is reversed or the plug on the vacuum is not polarized. Those things in combination could cause this but this is kind of a long shot guess. In any case the blower motor is likely burned out and will need to be replaced and checked out.
Jan 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Sparks and smoke
you either have something worn out or the motor inside is going bad. Sounds like the motor in the power head is going bad. Disconnect the the wand from the power head and flip over the head take the plate off. then take the plastic cover off uou should get to the motor then. look at all the parts. I would think you need to replace the brush roll, belt and motor. But this is just a guess
Jun 26, 2008 | Filter Queen Majestic Canister Vacuum
Smoke/motor?
I don't know in Nev. call Hoover's 800 number and they will tell you, the number is on the metal tag. But if it is the motor smoking, a motor will run you $85 to $95, plus labor, $40 to $50. But if this an electrical smell, then suspect the motor. But if it is a rbber smell, then maybe you have a belt that is slipping badly, replace the belt.
May 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Wiring Schematic
Hope this will help you. There is 4 different ways to hook it up depending on what you have,
Mar 14, 2008 | Vacuums
Schematic
Sounds like the motor has gone bad. But you need to go to sears.com, click on the part link, put in your complete model number, usually starts with 116.************. Then a parts list will come up and if what you need is there, you can order it thru Sears. Sometimes underneath the rear top cover, is a schematic
Dec 22, 2007 | Kenmore 25512/ 25513 Progressive Canister...
12 amp motor smoking
If the smoke is coming from the motor and I assume that it is, then your motor has gone bad and you will have to replace it.
Dec 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
56 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
