Question about MSI K8NGM-V Motherboard
I can't find an updated driver for my ASUS K8NGM-V H motherboard. My computer has started cycling reboot. Now it shows hardware with no drivers and I haven't a clue what hardware this might be.
    President:
  • 2,666 Answers
All asus drivers are available from here
http://support.asus.com/download/Download.aspx?SLanguage=en-us
Posted on Apr 28, 2010
Turn on an Asus eeepc1000 netbook with windows xp and the following is what came on the screen " Windows could not start because of a computer disk hardware configution problem. Could not read from...
this could be caused by a number of problems
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 28, 2011 | ASUS Eee PC 900, 900A, 901, and 1000...
My USB and windows vista does not recognize my new optical mouse from GE SKU# is 98543, my motherboard is an ASUS M2N-MX SE, my other optical mouse works fine but when i plug the RF receiver into the usb...
first check the battery inside the mouse make sure it is fully charged and well seated
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties hope this helps
Apr 01, 2011 | ASUS M2N-MX Motherboard
I need to upgrade my system to win 7 my motherboard ASUS P5b SE i have to get driver for motherboard compatable with win 7 please Help
ASUS doesn't show any drivers for Win7. It has drivers for Vista 64bit which MAY work for you. Follow the link below for these drivers and choose the Vista 64bit OS.
ASUS P5B-SE Drivers
Mar 23, 2011 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
My computer want soundmax reboot mier software carrupt file 39 no. my motherboard asus.
Download the soundmax driver by using the hardware id of the device.
you can locate the hardware ID by right click, properties, details, drop down, hardware ID.
Please refer the below link with the hardware ID to get the exact driver.
http://www.downloadwindowsdrivers.info/
Jan 22, 2011 | Computers & Internet
Sound driver is not getting installed in computer.motherboard series is asus P5GC-MX.
do you have the drivers?
if you dont have get one in the official website of asus...
extract the files in your document... right click your my computer... click the hardware tab..., device manager..
there is an exclamation point in your multimedia audio controller, right click it...
properties, click on the driver tab.. then click update driver... choose the 2nd one... "choose this if you see" install from a list(advance)then next...
and choose dont search... it is the 2nd one... choose show all devices... next w8 until it loads all the driver...
click i have this and browse it and choose the file where you extracted your drivers.....
Apr 16, 2010 | ASUS P5GC-MX/1333 Motherboard
Realtek hd audio input controller not working
Ensure that your mic is plugged into the correct jack.
Access device manager through control panel. Locate, right-click and uninstall the driver from the list.
Reboot your system and let Windows detect your new hardware. If this doesn't work, it may be that your operating system is recognizing your hardware but installing a generic or wrong driver.
If this is the case, go back to device manager, highlight the driver, but this time right-click and select reinstall driver. Make sure to include the drive and path (using the browse button) of the location of your updated drivers when the installation wizard prompts you to.
I hope this helps.
Regards, ~ redqew ~
Mar 12, 2009 | ASUS M2N-MX Motherboard
I not getting sound from my computer,I want to install M2V-MXSE ASUS. can u plz tell me where these sound drivers are available.......
either from the asus website, http://usa.asus.com/index.aspx ,or from Realtec, that is the hardware that asus normally uses on their motherboard. But just go to the asus site and click on the support and it will ask you the model number of the board that's it. You will see if there are any other downloads that came out for your board also. You should keep that link in your favorites. Here is the exact page for your board just download the driver here. thanks and dont forget to rate my answer, I appreciate it, thanks again,Gym
Dec 22, 2008 | ASUS M2N-MX Motherboard
Audio ClusterFk
You need thhe Microsoft UAA driver
Download them for your O/S
Uninstall any sound drivers then install the UAA drivers and reboot
If you have sound driver disk install drivers from it
If not go to Device Manager and right click sound driver and Update it .
it will go on net and find and install them
When done give me a fixya please
Nov 01, 2008 | ASUS M2A-VM (0610839149438) Motherboard
A8S-X no sound with vista
The latest XP drivers should do the job. Uninstall the drivers that you already installed. Unzip the driver files to a temp directory, then instruct the Found New Hardware wizard to search in the temp directory for drivers, or click on Update Driver through Device Manager then point the Wizard to search in the temp directory: SoundMax ADI1986A Audio Driver V5.12.1.5430 for Windows 2000/XP/2003: http://dlsvr01.asus.com/pub/ASUS/mb/socket939/A8S-X/ADI1986A2000XP.zip
Jul 09, 2007 | ASUS A8S-X Motherboard
MSI K8NGM-V Motherboard Logo
452 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
