Question about Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Pump slowly stopped runing and then the air pump also stopped. Will not restart but the power is on.
  • 661 Answers
Your description sounds very typical of a motor that is seizing up. It could be from debri contamination in the water (which I would check first) or a bearing could be seized. The air pump problem is most likely related to the water pump problem somehow. I would be concerned a breaker might be blown. should be blown actually.
Posted on May 18, 2010
  • rjk24 May 21, 2010
    i HAVE EMPTIED THE SPA AND DISCONNECTED THE PUMP AND BLOWER. i RUN THE PUMP DRY FOR A MINUTE AND IT SOUNDS LIKE IT IS RUNING BUT MAKING A SCRAPING NOISE AND THE BLOWER SEEMS TO BE BLOWING JUST FINE. COULD THIS BE TRASH IN THE PUMP? iF SO HOW DOES THE PUMP COME OUT , i HAVE REMOVED THE 4 BOTTOM SCREWS BUT THE PUMP STILL SEEMS TO BE CONNECTED TO THE UPPER HOUSING BELOW THE FILTER HOUSING.
  • Bryan Fullerton
    Bryan Fullerton May 21, 2010
    Ok you got me on that one. If the motor was running but water wasn't moving then the impeller came loose from the motor.
    To take it apart and fix it depends on the pump model. Some they glued together and if that is the case you cant get to the impeller. You have to buy a new pump. Usually they do come apart though. You just have to find the seams and look for the screws. If I had a few good pictures of the unit I might be able to tell. Not sure if I have seen that exact model pump before.
5hp air compressor pump
sounds likeyour pressure relief vavle may be filing . they let the unit restart properly when there is still pressure available for use
Jul 05, 2016 | Plumbing
My 96 s10 stop runing so i change fuel pump and now it still wont start and the pump isn't getting power
try replace fuel pump relay under hood I think its on drivers side fender or fire wall .
May 04, 2014 | 1996 Chevrolet S-10 Pickup
Was runing fine then lost power still runs
disconnect the MAF SENSOR located before the throttle body on the air intake. the car should run better but not perfect. if the car runs better change the sensor
Mar 14, 2014 | 1999 Ford Explorer
2002 Ford Thunderbird, power steering semi hard, makes whining noise in power steering system when wheel is turned
fords are notorious for this problem . the noise your hearing is air trapped inside the pump . try to bleed the system by slowly turning the sreering wheel from stop to stop . if you still have a problem it might just need a new pump . very inexpensive easy fix
Aug 27, 2013 | 2002 Ford Thunderbird
What's your problem?1998 dodge caravan fuel pump no power
the fuel pump working good and the relay too , i change the egr valve and another valve go in the air filter and nothing . now when i put the swicth the pump start runiing and them stop them start runing alot of time . now i check in the fuel injector if i got gas them i push the little thing in the injector them push a lot of gas .... now today i go put down the gas tank i go make sure if not have a electrical problem in the fuel pump. i hope this is the problem .....
Sep 14, 2012 | 1998 Dodge Caravan
On a 96 grand am the fule pump won't stop runing.
Running never stop,it not the wiring,check the power soure that give the feul pump it power.
Nov 24, 2011 | 1994 Pontiac Grand Am
I have 95 jeep grand cherokee i replaced power steering pump and gear box and i still dont have any power steering
Did you bleed the power steering pump after you replaced it. I know its a dumb question, but I have seen it before.Slowly move the steering wheel back and forth from stop to stop. Make sure the fluid is always full or you will reintroduce air into the system.
Jul 18, 2011 | 1995 Jeep Grand Cherokee
I replace the power steering pump on my volkswagen passat 2001 and is making kind of squealing
The noise is probably caused from air in the steering system. To bleed the air out of the system, start the engine and turn the steering wheel back and forth slowly, but do not turn it all the way to the steering stops. Continue to do this for several minutes. The air will slowly bleed out of the system. If that doesn't stop the noise, then it could be the belt slipping.
Jan 23, 2011 | 2001 Volkswagen Passat
2004 ford f250 powerstroke. brake pedal is hard to press at first then goes straight to the floor also power steering quit working at the same time.
Hmm.. Low fluid in the power steering pump, broken belt driving the power steering pump, failed component causing loss of power steering fluid, failed power steering pump.
Check for a broken belt first, check the oil in the pump, look for leakage under the truck.
If the pump is low on fluid you want to put about half the amount in that you're going to need and then start the truck and turn the wheel slowly from stop to stop, each way- spend about ten seconds going from one stop to the other. This will allow any air in the system to be purged out in a controlled fashion, it can really spray if you get a big, compressed bubble of air in the system and release it quickly. Shut the truck off and top the steering pump up, check for leaks.
lp
Jan 05, 2011 | 2004 Ford F250
Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White  Logo
159 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
