Question about Logitech X-230 2.1 Speakers
The speaker with the audio jack isnt playing any sound.
  • 29 Answers
Can be a bad signal cable, or even a problem with your control unit. Have you checked the wires, these models tend to wear quicker with the control unit attached to the sub. Check to see if another pair of speakers work just in case, if so, its either the wires, which you can check, or the system might be shot.
Posted on Apr 28, 2010
My speaker wire part where you put it into the computer is on its way out for music to play I have to fiddle with it and I don't know what the wire is called so I can buy another
it seems like the output jack of your pc isnt fairing well and does sound like it needs replacement but i cant tell if the speaker wire your connecting to is a desktop or to a laptop but by all means it does sound like the output jack is damaged and need of repair
Feb 26, 2017 | The Audio Players & Recorders
Psp go no longer plays sound from the speakers
make sure the mute isnt on. try resetting to default setting
Aug 24, 2014 | Sony - Go for PSP
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
I shocked the stereo jack for my 5300e when i was going to plug it in after taking off my coat. it made a loud noise over the speakers and now the left front and rear channels only very very faintly play...
you have probably damaged the amp chip. inside the radio on the back wall there is a chip with around 10 pins on it that chip is the amp it controls the volume and the left right and front and back, that part will need replacing.
Jul 16, 2017 | Logitech Z-5300e Surround Sound System...
My speakers isnt working anymore i dont know why tha lights are going on everything seems 2 be fine before when i touched tha 3.5mm jack it made a strange sound that how i know it was working but now it...
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Harman Kardon SoundSticks II Computer...
JBL Speakers won't play
Check all your connections. it might be that the green audio jack isnt put into the rear of your pc properly.
Jan 02, 2010 | Audio Players & Recorders
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
Laptop speakers & hp jack dont work, works with line in only
first try to reinstall audio drivers, remove audio device from device manager, install new drivers.
Apr 13, 2009 | Dell Latitude D820 Notebook
Mp3 player only plays on right side speakers
Have you tried a different jack? It could be faulty.
Aug 11, 2007 | Pioneer DEH-P6800MP CD Player
Logitech X-230 2.1 Speakers Logo
65 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
