Question about Acer Extensa 4620 Notebook
Won't load While working on my laptop it shut down out of nowhere, and now, when i try to start it, it will turn on to the screen that says microsoft and has the green light that flashes from left to right on the screen while loading, but it will never leave that screen and continue loading.
  • Acer Master
  • 1,606 Answers
Something is having a problem loading. Usually these are drivers or the last program installed.
When you boot start pressing F8 as soon as you see something. This is before the windows screen so you have to power on and start pressing F8. Then select Safemode. This will boot up windows without loading any drivers. Once you are in safemode then you can go to control panel and uninstall the last thing you installed. sometimes just booting into safe mode and then shutting down and rebooting normally will clear the error.
Having said that this can also be casued by a virus that has damaged windows files. You can repair your windows setup if you have the windows cd. If you have to use the system restore it may allow you to repair or attempt to but usally will try to wipe out everything and set it back to factory.
Posted on Apr 28, 2010
Toshiba laptop wont let me login
have you tried the steps listed at the microsoft website?: http://support.microsoft.com/kb/947215
Dec 02, 2012 | Toshiba Satellite A100-S8111TD Notebook
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
Won't find solution to problem and start up
While booting up you should try holding f8 right after the manufacturer splash screen the select safe mode with networking once in there you will want to restart the computer if all is well it will boot into windows! hope i could help =]
Mar 01, 2012 | Toshiba Computers & Internet
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Hi...i'm trying to boot my comp however it doesnt seem to want to get past the microsoft corporation loading screen....d2d doesnt seem to work either
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Dec 20, 2010 | Acer Aspire 6920 Notebook PC
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
Laptop Shuts down to black screen without warning.
it may be over heating !!
turn it on and run it till you hear the fan turn on, then check if there is much air coming out of it.
if not use a vacuum to **** air throw it as you blow hard into the slot that the air should come out of
Jun 17, 2009 | Gateway 450ROG Notebook
I have an acer aspire laptop, when i start it up its says configuring updates stage 3 of 3 0% complete then it will shut down come back on say the same again and shut down again. it will keep on doing this
Maybe you could try the last known good configuration. When the laptop is starting up, wait until the acer screen disappears and then tap F8 on the keyboard before the windows screen comes up. You should get a black screen with some options that say safe mode. The fourth or so option on the list will be "Last Known Good Configuration". The computer should try and load windows. Hopefully that will restore the machine before the update.
If it works it would be a good idea to go to http://windowsupdate.microsoft.com/ and fully update your laptop. This will download the update manually instead of doing it with automatic updates.
Oct 14, 2008 | Computers & Internet
Acer Extensa 4620 Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
