Question about Thermos Stainless Steel Gas Grill
Dual fuel thermos m#461262006 swicth back to propane
I inherited this grill. it was being used with natural gas. dont have manual. what do i need to do to switch back to propane? i already connected regulator and have flame but seem too orange color to me.
  • 8,197 Answers
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Posted on Apr 28, 2010
What is the difference between duel fuel or gas..? Does one allow you to change grill to griddle?
"Dual fuel" normally indicates that the appliance can use either natural gas or propane.
Oct 14, 2013 | Thermador PRG484GGUS Gas Kitchen Range
I cannot find a supplier who can provide an LP to nat gas conversion kit for my 4 burner grill made under the name: Ducane, model # 30400040. Can you assist? Marlin
Perhaps, the reason you can't find the fuel conversion parts is that they are not convertible from one fuel type to another. Ducane/Weber makes both an LP model and a Natural Gas model of your grill, but no conversion kits. Because, as the Owners Manual states "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty."
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3400_4400_NG_OwnersManual_27010342_061008.pdf
Certainly, you could attempt it, Marlin . But it's not the wise thing to do.
I know this wasn't the answer you may have wanted, but I hope it helps you.
May 06, 2011 | Ducane 30400040 Stainless Steel Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Thermos Stainless Steel Gas Grill Logo
402 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
