Question about Dishwashers
Dishwasher does not drain completley after running
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Apr 28, 2010
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
Water does not Pump off completley.
This is a really common problem that most people send hundreds when they can fix it themselves. Power off your washer, put it on its side. Your going to see four to six silver bolts with hex heads located in the center holding in a plastic device known as the filter assembly. Remove the screws and find any hair inside the assembly. Remove the hair and put the screws back in. Even the smallest amount of hair inside the filter/drain assembly will cause this problem.
Jan 27, 2011 | Siemens Dishwashers
How to remove waste hose from machine?
1 Turn off the circuit breaker that controls the dishwasher.
2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
Dishwasher does not drain completley after cleaning. but if i hit cancel/drain the water will drain
You have to check the pressure switch/level switch. refer to a service provider.
May 21, 2010 | Dishwashers
I accidentally put liquid detergent into the rinse compartment.
Wipe down the rinse compartment, fill it with tap water and run as many empty cycles as it takes to flush out the improper additive.
If you put Dawn or Joy type detergent rather than machine detergent it may take awhile but it works once the unwanted chemical is flushed out completley.
Don't work to hard, let the machine do the work for you.
Dec 28, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
How to protect my dishwasher in a non heated cabin in freezing t
hi there.......best to remove it from its position at the end of your summer vacation....drain it completley..of all water.....pack it into a container (large cardboard box etc) lined with polysterene etc....
regards Sir Galahad
Sep 03, 2009 | Dishwashers
Water is left in the cavity beneath the base filter
water under the filter is normal. Most diswashers do not drain completley- this acts as an air lock to prvent odours coming thru the drain hose
Jun 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Superba Kudso15l551
check the check valve it may have something in it.
Jun 10, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Zanussi ZT685
Dishwasher2_bing.gif Problems - Water will not drain out
heatman101
Dec 21, 2007 | Zanussi ZT485 Built-in Dishwasher
Dishwashers Logo
109 people viewed this question
Top Dishwashers Experts
