Question about Samsung SyncMaster 216BW Monitor
Backlight going bad?
Samsung 20" Syncmaster 204B Monitor is dark when coming out of low power mode, then flickers and finally gets brighter until it reaches its normal brightness. Looks to me as if the backlight may be going bad.
  • Samsung Master
  • 1,684 Answers
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 28, 2010
Testimonial: "I know this has been quite some time ago, lol. I did since replace the capacitors and still had an issue. There was another component that went bad (can't remember what) which was too expensive to replace given the price reductions on newer bigger monitors. Thanks for your help!"
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
I GOT NEW PC BUT ON OLD PC MONITOR WOULD COME ON DARK THEN GRADUALLY BRIGHTEN UP BUT THEN AFTER IT WAS FINE I THOUGHT WAS MY PC CUZ WAS HAVING TROUBLE WITH THAT AS WELL BUT WHEN I HOOKED MONITOR UP TO...
The 204B monitor have a known issue with power supplies that start failing and you get the "slow to show picture" problem just like you have. The monitor is very easy to repair and the parts are low cost. Here is a link to our repair guide http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ If you can solder then you can fix your monitor. If you don't want to repair it contact me and we may be able to buy it from you for parts.
I hope this helps, if so please rate my solution.
BuddyMc
tech@ccl-la.com
Aug 06, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
When I attempt to bring it back up, or turn it on,monitor screen stays black long time, then flickers, then slowly, ever so slowly, comes into view. Works ok at that point. Happening every time now, and...
The Samsung 204B monitor have a know issue with failing power supplies that cause the exact problem you are having. At first they are a little slow to display a picture and the more you keep using it the longer it takes for the display to come on. The repair is simple if you can solder. Here is a link to a site with additional information on this repair. http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This Samsung 204B monitor is a great unit with a simple to solve issue. No need to trash a good unit.
I hope this helps, if so please rate our solution.
BuddyMc
Jul 04, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
SyncMaster 204B screen appears in 5 min after turning monitor on. First 7-10min screen is dark and slowly increases brightness. The picture becomes normal in 15-20 min and all is OK until the monitor is...
How long have you had the monitor. It sounds like a defective backlight. Usually when the circuit driver for the backlight starts to go bad, the monitor will blink. If this is the case, eventually the monitor will not turn on at all.
Jan 12, 2011 | Samsung SyncMaster 204B 20.1" LCD Monitor
Flickering and then no picture
punchjackson, You or qualified electronics technician will need to open and visually inspect switch-mode-power-supply board to possibly determine cause of SMPS going into partial or full shutdown mode. Do some reading in fixya profile of "louie12fix" and then visit links you find there. Remember this!!! The basic design and operation of your 204B isn't any different than any other "cold cathode fluorescent-lamp" back-lit LCD monitor. Inspect all solder joints and electrolytic filter capacitors first. Then let us know what you find. Also do a visit to YOUTUBE for lcd monitor repair videos and see what a Bad Capacitor looks like before you open your unit. 12fixlouie
Apr 09, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My HP monitor recently started doing strange things. 1. It is red all over when it first wakes up. This fades after a few seconds. 2. It is flickering. 3. It is noticeably brighter on the left side. Is it...
you need your power supply repaired. take the back cover off and look at the power supply for crowned and or laeky capactiors. desolder them and take them to an eclecronics parts store. replace them and yourr good to go.
Dec 26, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204b my screen flickers and is dim on wakeup
Your backlight power supply is about to die. Check out our web page at: www.ccl-la.com/badcaps.htm We have a full repair guide and parts list to do the repair.
Buddy
Corporate Computer
www.ccl-la.com
Sep 27, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Display problem of samsung syncmaster 450B & 550s
BAD NEWS THE PICTURE TUBE IS WEAK THE ONLY FIX IS TO REPLACE YOUR MONITOR WITH A NEW ONE
Apr 28, 2007 | Samsung SyncMaster 550S Monitor
Samsung SyncMaster 216BW Monitor Logo
1,329 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
