Question about InFocus ScreenPlay 5700 Multimedia Projector
Projector will not power on.
I can see the fan running lightly with a green glow but the unit will not beep and start up.
  • 74 Answers
Since you see a the power button light up green there is a chance that the power supply is still good. Try updated the firmware. You can get it from the infocus website. If that doesn't work then something is wrong with the power supply. I can repair it if you'd like. My ebay screen name is gtitubro.
Posted on May 12, 2010
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Epson 84+ green light blinks no light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
May 21, 2012 | Epson Corporati PROJECTOR, EPSON,...
Green light on power supply flashes rapidly when I plug the computer in. Computer will not power up at all (no cooling fans start, no lights illuminate and no beeps come from the unit). When the power...
if the cooling fan on your PSU power supply unit does'nt spin when you start your PSU is faulty if it does then
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 21, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
No light and some fan noise
Take the top off and verify that all of the fans are on, there are 2 behind the power supply and one behind the engine. If the unit lights up when the top is off, then the wires above the dual fan assy may be putting pressure on the fan frame while the top is on causing one to rub or not turn at all. If this is the case, unplug the power and try to route the cables thru the notch in the top of the fan assy a little better. If any fan isn't working, the unit will not light. This could be due to a main board problem or a bad fan itself. If the colorwheel is stuck, the unit will light and then shut off. Also, depending on the age of the projector, if there isn't a green wire going from the front of the main board to the bottom of the power supply ballast, the power supply will need to be replaced or upgraded by a technician.
May 03, 2010 | InFocus LP70+ Multimedia Projector
Unresponsive, lamp dies upon start
if you don't hear a high-pitched whir, the colorwheel is shot and needs replacing. if you do, one of the fans might not be working and the heat shuts it off so as not to cause damage.
Oct 15, 2009 | InFocus ScreenPlay 4805 Multimedia...
EIKI LC-XNB4MS POWERS ON AND FANS START FOR 15 SECONDS AND THEN O
the lamp is near the end of it's life. time to replace it.
Mar 20, 2009 | Eiki LC XNB4 LCD Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Infocus 4805
I think the problem is the ECA controller (main board). It is through this that the fans are powered. Try to measure the voltage supplied to it (CN377 on the board for the larg lamp fan CN376 for the smaller fan), it shouldn't be less then 5v this can only be achieved if you activate the lamp door switch by jamming a piece of card board in it and powering the projector up. Take caution, and don't touch anything else, high power voltages are also present. You could also try to supply the fan with an external supply 6 to 12 volts after you unplug it from the main board, to make sure the fan is OK making sure of the correct polarity, red wire is +, black is -.
Oct 26, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 5700 Multimedia Projector Logo
152 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
